Is this going to cut correctly?
michelle
Post by michelle »
Can someone take a look at this file and tell me if it looks like it will cut correctly? It wasn't right when it was done originally but I 'think' I have it fixed, I just need an expert to check it before I waste more material!
Thanks guys!
Michelle
hornet.pcm
(469.17 KiB) Downloaded 75 times
Re: Is this going to cut correctly?
Try posting this in the file sharing forum and you will reach more members and likely get the help your looking for. I cannot open pcm files or I would take a look.
michelle
Post by michelle »
I cut it and it worked. Thank you!
rdj357
Post by rdj357 »
Here you go, I cleaned it up and fixed the unlinked paths out in the middle that were piercing on the path. Bridged in some details in the wings that were fallouts, reshaped the left eye and added a touch of detail, thickened the antennae just a little for strength, and scaled back some open path details that were close to cutting to the edge. I do custom file work if I can ever help - robert@490Creations.com
Hope this helps a little!
hornet.pcm
(437.86 KiB) Downloaded 61 times
hornet.dxf
(808.2 KiB) Downloaded 72 times
