Corner Weld Jigs
Corner Weld Jigs
corner welding jigs i drew it for 3/16
Re: corner weld jigs
Thanks. Any good welders on here have any tips on welding sequence so it doesn't twist like a pretzel? My brain usually tells me the exact opposite way to weld it.
- Scratch
Here's a good video on a build of a similar one.oldironrep wrote:Thanks. Any good welders on here have any tips on welding sequence so it doesn't twist like a pretzel? My brain usually tells me the exact opposite way to weld it.
https://m.youtube.com/watch?v=_-JlHM_EWf4
Maybe tig weld just the outside tab inserts, then lay a piece of one inch over it and clamp it down till it cools, it shouldnt twist that bad, if you dont have any one inch, use some aluminum 1/4 plus thick and clamp it to a table, it will draw the heat out quicker.
thats what i wasgoing to do just weld the outside off the tabs and maybe tac the endsBradley wrote:Maybe tig weld just the outside tab inserts, then lay a piece of one inch over it and clamp it down till it cools, it shouldnt twist that bad, if you dont have any one inch, use some aluminum 1/4 plus thick and clamp it to a table, it will draw the heat out quicker.
hears in adjustable one
These should come in handy. Thanks!
- TimP
Re: Corner Weld Jigs
Thank you for the share!
A nice addition to the welding table.
Tim
Tim
Thanks for sharing.
thanks guys great ideas
look up back step welding
Jim
Jim
- Capstone
I made up a pair of these... thanks for the share. check out my Instagram for a pic.
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
CNC Metal Design
JD Squared 4x8
- steel 35
Shaweet
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
Hyp 65 duramax's
EasyScriber
- steel 35
Except know I need a scribe!
Never mind I have one in the mail
Thanks Plasmaspider
Thanks Plasmaspider
PPL HDG 4X8
Hyp 65 duramax's
EasyScriber
Hyp 65 duramax's
EasyScriber
Thanks, I have been wanting a set of these.
Thanks, Very nice.
Cool, thanks guys!
I've been meaning to draw up some adjustable ones, now I don't have to! Thanks.
Bill
Bill
- ETCWeld
Thank you for sharing this
great files cheers for the share
Thanks for the files, I think the adjustable one has many uses may find a spot on the surface grinder table
Thanks for the share i just made a bunch of squares myself!
Thanks for sharing!
The last one looks like the certiflat kits that I bought, which I really like.
Edit: I found your other thread and grabbed the file for those. It will be great to be able to make more and save some money.
thanks for sharing!
Thank for sharing, the adjustable one looks like it will definitely come in handy, I may have to get 10 or 12 of those cut
