Lion Face Cutout
Zache82
Lion Face Cutout
Post by Zache82 »
Ran into this lion while searching the sharing forums and I decided to change it to be a cutout so I could hang it. I broke apart the whiskers and converted them back to polylines and sheetcam is saying they're broken. Could someone please have a try at it or tell me what i"m doing wrong? Thanks.
Using QCAD and Sheetcam.
Credit to Compnerd88 for the lion
Original post :
http://www.plasmaspider.com/viewtopic.php?f=6&t=2360
lion.dxf
hemichargersrt8
Re: Lion Cutout
Post by hemichargersrt8 »
Here you go Zache82, I also adjusted the nose area to join a couple "drop" areas. I think you may have cut problems as it is currently sized. I may be wrong but I would scale it up a bit.
Also just a quick shoutout to Compnerd88 who did a great job creating the original file.
LION CLEANED.DXF
Zache82
Re: Lion Cutout
Post by Zache82 »
Thank you, hemichargersrt8. Is there a general rule you follow to know when to increase or decrease to avoid cut problems? I've only been doing this a few months.
hemichargersrt8
Re: Lion Cutout
Zache82, Ok, good question. My concerns where with the width of the long slender whiskers and lines above the eye brows. These thin areas may burn off when cutting as they are so narrow. I try to keep at least 2-3 times the width of the kerf(cut) width in these areas.
Re: Lion Face Cutout
This is awesome. Thanks guys!
Strawboss
Post by Strawboss »
Thanks for the share
david jordan
Post by david jordan »
Thank you, very nice.
PlasmaCam DHC 2 4 X 4 table
Powermax 65
400amp mig welder with dc tig
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Sothbend, 5C collets
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Bradley
Post by Bradley »
Thankyou. I think this maybe a good firepit insert also!
