Grinder stand conversion, help!
Desertdog
Post by Desertdog »
I want to make a grinder stand for my new Jet grinder with multitool. The drawing is attached, base and mounting plate. Will go to the yard for a piece of large square stock or I beam to weld together. The holes for the grinder mount could also be slotted.
DXF file is fine, I can convert to sheet cam.
Needless to say I haven't even made it to CAD challenged...
Thank you
GRINDER STAND DRAWING.pdf
Westcott Retro 5x10
Design2Cut software, CAD, CAM, CUT, all in one program.
Hypertherm 45XP
Champion 2 stage compressor, 7.5 HP motor, 15 HP pump (QUIET!),
80 gallon tank, auto tank drain, mag starter, after cooler.
25.8 CFM@175
hemichargersrt8
Re: Grinder stand conversion, help!
Post by hemichargersrt8 »
base.DXF
grinder stand.DXF
Desertdog
Post by Desertdog »
Thank you !
Westcott Retro 5x10
Hypertherm 45XP
25.8 CFM@175
Very helpful, thank you!
