new toy Plate Roller
Re: new toy Plate Roller
Thank you Acourtjester for sharing the pictures of the roller. I made one just like yours and it works to. I didnt have a project to make yet with it but I always wanted one. I had a motorized worm drive taking up space in my garage for the last 20 years and I finally found a use for it. Very happy thanks again, Gary
Happy to help great project.
Have fun
Have fun
Great project! How are the 3 components of the rollers joined together? Welded? Pinned? If welded any issues with warpage? Thanks!
If you are talking about the rollers, I tack welded the shaft and DOM tubes at the ends to form a solid roller. I just ground a notch and filled the notch with welding.
Yes that is exactly what I was asking. I appreciate the pix - Thanks!
Would I be able to get the plans for this plate roller also? This would work great for wheels and other items that I have been doing on a Shop Outfitters roller and would be able to do a lot wider also. Great job on both of the projects and very impressed on the star embossing .
Thank you
kdahep
Thank you
kdahep
I don't have plans per say but if you PM me with your email address I will supply you with any info you want.
Well I have mine almost finished , Its actually working but need to fine tune it and get it cleaned and painted up / Thanks acourtjeter for the information . not sure how to add photos but will work on getting a few posted of it ..
4x8 Delusional designs cnc
Hypertherm 45xp
Kobalt 60 gallon
Hypertherm 45xp
Kobalt 60 gallon
Happy to help Just a little pay back for the help I have received
That is one beautiful design and fabrication. I can only say WOW!!!
Yes, this is awesome Jester! Can you tell how much you have into it roughly? Been looking at the crappy 3 in 1's out there will barely do 20ga and everyone wants 90% of retail for used!! Also if you have plans, part numbers or all of the above I would love to get a set!
Bulltear 4x8
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
C&CNC Bladerunner Servo
DTHC IV Feather Touch
HyT-Connect DCP-01
Sheetcam Inkscape QCAD
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
HyT-Connect DCP-01
Hi tylerd
I cannot give a accurate cost as I used some of the metal I had laying around. I could send you info and where I bought the sprockets, bearings, and the tubing so you could check the prices. Just PM me with your email address (a non-Yahoo would be best)
PM Sent
Bulltear 4x8
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
HyT-Connect DCP-01
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
HyT-Connect DCP-01
PM sent too
PM sent too
need to build one of these, does anyone have a source for the gears and chain? what number of teeth and pitch?
Parts for Plate Roller ordered from Surplus Center
#50-10 10' Box Of #50 Roller Chain
Item Number: 1-1163-50
17T 1/2 Bore 50P Idler Sprocket
Item Number: 1-2410-17-A
19T 1 Bore 50P Sprocket
Item Number: 1-2124-19-E the roller uses 2 of these
Truly, a master at work....
I am so humbled.
I am so humbled.
- Nacs Fab
I cannot wait to start this winter Project. Thank you acourtjester for all your knowledge you bring to this forum.
G540 with LCTHC by candcnc
all built... by me...
Happy to help
I have been trying to design something like this in my mind for months! Your idea and pictures finally brought it all into focus. I am assuming you nested the 3 pieces together to form one roller, with the solid round stock being used in the carrier bearings?
I realize this is an older thread, but do you happen to have the dimensions of the 3 pieces?
Thank You for sharing this,
Carl
Carl
PlasmaCam DHC2
Hyperthem PM65
Edwards 25T Ironworker
Hyperthem PM65
Yes on the 3 parts for one roller, here is a PDF with some dimensions.
Thank You!!
PlasmaCam DHC2
Hyperthem PM65
Hyperthem PM65
That is really, really neat. How thick was the metal you pressed the star shape into?
The finished star was 18 Ga, and the star press was 3/16" or 1/4"
