sheetcam ?
kennye
sheetcam ?
Post by kennye »
Can someone tell me why sheetcam devl is not generating but about 8 r 9 lines of code standard sheetcam is good
attached is a screenshot appreciate any help thanks
Old Iron
Re: sheetcam ?
Post by Old Iron »
Post the dxf, svg, ??? file and someone will look at it for you.
kennye
Re: sheetcam ?
Post by kennye »
The file is good I can run it in standard sheet cam and it generates code as with every dxf I try .
only with sheet cam development do I have trouble and I think I need that with the height sensor Im trying to get going.
Old Iron
Re: sheetcam ?
Post by Old Iron »
I see. I'm not gonna be any help with Sheetcam Dev.
kennye
Re: sheetcam ?
Post by kennye »
Thanks just the same.
Re: sheetcam ?
Post by tcaudle »
What Post Processor ar you using in dev SheetCAM?
Les Newell
Re: sheetcam ?
Post by Les Newell »
That looks like a license problem. Try reinstalling the license. If that doesn't work send me the license ID in a PM or email and I'll check it for you. You can find the license ID in Help->about.
Return to “SheetCam”
