Mk3 Diy breakaway torch mount
- SeanP
Had to go a little bigger for the new Duramax torch so had a rethink.
Easy enough to make up, you just need 3 x 12mm bearings and 2 magnets (I cut one in half)
Bearings tig welded in, magnets stuck with double sided tape.
Torch clamps I used 10mm and 5mm for the plates.
I can post detailed info & dxf if anyone wan'ts them.
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
Table build gallery
- Scratch
Re: Mk3 Diy breakaway torch mount
Nice and simple... I like it!
- 4.5 Star Member
Thanks Sean,
I think I'll be using this principle when I make my breakaway. Cheap, easy and looks effective.
Who needs to pay $300 for a breakaway.
Keith.
Keith.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
LinuxCNC
Coreldraw 2019
Looks like the old "KISS" process still works, very nice I'm sure it will be copied.
Are you going to put a disconnect switch with it?
- SeanP
It's about time I did, I've had 2 leaks in the tray due to knocked off torch using previous designacourtjester wrote:Looks like the old "KISS" process still works, very nice I'm sure it will be copied.
Yes it works really well, better with the bigger bearings, took a bit of playing around with getting right hole size and magnet position, I'll edit post with details soon.
Powermax XP45
Table build gallery
Table build gallery
I your a good man Gunga din
- SeanP
Had to google that one
Powermax XP45
Table build gallery
Table build gallery
Showing my age again
- steel 35
Those clamps cut out very nice, & the whole package is sweet.
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
Hyp 65 duramax's
EasyScriber
Looks great. I'm looking at upgrading my table, it uses a set of ball bearings to run on the plate and a pneumatic ram to lift the torch.
I'd like to change it to something like yours, with THC. Just not sure what to go for at the moment.
I've had a couple of torch collisions over the years, really like your idea.
Will.
Will.
- SeanP
More info added to post and dxf files for parts.
Powermax XP45
Table build gallery
Table build gallery
Thanks Sean.
thanks again
filed away to due when I get home
Thanks, that is a great idea I have been thinking about building one but I had not come up with a good idea yours looks great! Thanks again.
I accidently found a youtube video of shapes you make using magnetic balls. It may take some experimenting with placement, but that would knock out 2 birds with one stone. I don't have a torch set up yet, since I am in the planning stages.
I could make this my first cut, but if something goes wrong during setup...
Would anyone mind selling me the metal cut outs?
https://www.aliexpress.com/item/50pcs-1 ... autifyAB=2
[quote="Greg_R"]I accidently found a youtube video of shapes you make using magnetic balls. It may take some experimenting with placement, but that would knock out 2 birds with one stone. I don't have a torch set up yet, since I am in the planning stages.
Edit: that link is not magnetic balls...
I'll go with the square magnets like you did. Do you mind telling us the size and strength of the magnets? There are all kinds of strengths.
Edit: that link is not magnetic balls...[/quote]
Sorry don't know what's wrong with the forum and the double posting when editing.
- SegoMan DeSigns
Nice design,
You could add tabs to the torch mounting piece to hold some alignment lasers as well. The ones on fleebay require a 1/2" hole.
- SeanP
Have a look on that drawing Greg, the magnets I used are 19x 29 with one cut in half for the top two, been using it for a while now and it's spot on, very easy to lift off and re-locate, just the right hold.
Na don't bother with the mag balls, be a right pain welding those on!
Powermax XP45
Table build gallery
Table build gallery
- SeanP
Good idea, I really would find those usefulSegoMan DeSigns wrote:Nice design,
Powermax XP45
Table build gallery
Table build gallery
- trtilton61
Thanks,great looking set-up.
Precision Plasma HDSE-4x8
CandCNC Bladerunner dragon cut
Hypertherm 65
Mach3
sheetcam
Hypertherm 65
Mach3
sheetcam
Yes I did see the size of the magnets after posting that. Thanks so much for sharing!SeanP wrote:Have a look on that drawing Greg, the magnets I used are 19x 29 with one cut in half for the top two, been using it for a while now and it's spot on, very easy to lift off and re-locate, just the right hold.
