Tight bender dies for press brake
tc4x4
1/2 Star Elite Contributing Member
Post by tc4x4 »
These are some dies i built to allow tighter bending on a single piece.
bender dies.DXF
BAR M
Re: Tight bender dies for press brake
Post by BAR M »
thank you very much
Ghettoman
Post by Ghettoman »
Any pics of it in action?
Old Iron
Post by Old Iron »
Ghettoman wrote:Any pics of it in action?
I'm in the need to see category too :?
Tugdriver
Post by Tugdriver »
Are you laminating several together to make a punch?
Like this?
We have done that where I work to make a specific bottoming radius die or a specialty die.
I'm still not sure what the notches are for though.
yroc fab
Post by yroc fab »
The notches look like they are there to run a bead across them to weld the plates together.
Tugdriver
Post by Tugdriver »
Excellent point. I think you are correct. I forgot about that.
T Wayne
Post by T Wayne »
Good point, I thought maybe they were clearance for a piece of round stock to weld across.
tjenus
Post by tjenus »
they work quite well, I just been throwing them in on any extra sheets, not to concerned about the thickness of the plate either because of the lamination, thanks KH
5x10 Flow Waterjet
Faulknerm
Post by Faulknerm »
Thanks for the share! I was just about to draw this up when I stumbled across it
Faulknerm
Post by Faulknerm »
I had to adjust them a little, but worked great
Davewynes
Post by Davewynes »
great file cheers for the share
tc4x4
Post by tc4x4 »
Sorry, I have been super covered up since I posted this. The notches are for welds, I have several welded together, I have cut several out of 1/2 inch I have them spaced in 1 inch increments i.e. 1", 2", 3". I will get some pictures up some time after Christmas.
weldcutbend
Post by weldcutbend »
i would be interested in pics if you have any. my brain isnt firing right for some reason haha...
cstroke
Post by cstroke »
Raising an old post from the dead..
Any pics of these in action??
Chris
6’x12’ Dynatorch powermax 85
12’ Wysong brake
5’x 5/16’ wysong rolls
3.8’x10’ shear
65 Ton ironworker
Boss laser 3655 150 watt CO2.
SFX 100watt Mopa
Quicncy 7.5hp
ETCWeld
Post by ETCWeld »
tc4x4 wrote: Fri Dec 22, 2017 5:51 pm I have cut several out of 1/2 inch I have them spaced in 1 inch increments i.e. 1", 2", 3".
I thought i knew what was going on until i read this part.
X53Gunner
Post by X53Gunner »
Thanks a bunch
zoeconner
Post by zoeconner »
Any pics?
6 cylinder puller
Post by 6 cylinder puller »
any other dies you have made for the swag off press ??? I wish I would have seen these before I bought my dies
6 cylinder puller
I thought about making a press shear out of it also
WCFields1965
Post by WCFields1965 »
Thanks for the files
Kwikvette
Post by Kwikvette »
Old thread but someone might find the files here useful.
With that said, has anyone cut a set of these out? I have found no pics at all.
How far up/down would I need to scale the drawing to fit the Swag 20 ton brake?
Kwikvette - I think you need to become a contributing member to see pictures and download files. I have all of the Swag Offroad press brake dies including the gooseneck dies. If you click on the link below you will be able to see my image showing the difference between the Swag Offroad version and the ones posted at the top of this thread.
The key difference is the width of the tang which inserts into the die holder bar. The Swag Offroad dies use a 3/4" width, while the version posted in the dxf uses a 1" tang width. If you scale down by a factor of 0.75 this will result in the correct tang width to fit the Swag Offroad press brake. Another option would be to simply edit the file and narrow the 1" tang to 3/4", while leaving the rest of the die the same size.
https://photos.app.goo.gl/JFwHxn2inTDDktbz9
yroc fab wrote: Mon Oct 02, 2017 2:56 am The notches look like they are there to run a bead across them to weld the plates together.
Kwikvette
Post by Kwikvette »
David, I very much appreciate the information!
I am aware I'd need to become a contributing member for downloading said files, but not for viewing images (won't show me any images here other than the one you linked). Just wanted to see one of these home-made dies either in use, or even just in one's hand.
My only concern at this point would be dialing in my settings for 1/2".
Thank you again for chiming in!
