It is currently Fri Apr 20, 2018 2:33 pm
Vader Chiefs Mess
DXF Art Sharing Forum is for sharing dxf, plt, or any other vector file for plasma cutting. Browse what others have posted or post some DXF art files of your own.
goldwinger
Vader Chiefs Mess
Postby goldwinger » Fri Sep 08, 2017 11:24 pm
Need to convert this into a DXF file approx. 12.5" x 12.5"
any help would appreciated
Arc Pro 4800
PowerMax 45
Mach 3, Sheet Cam
Inkscape, Paint.net
Cz_apie
Re: Need Help Please
Postby Cz_apie » Wed Sep 13, 2017 8:49 am
Try this one
Vader chief.rar
Deon
Plasmacam 4x4 DHC2 Table
Design Edge 4.36 Advanced Design
Advanced Height Control
Hypertherm PM 65
Mac Afric Cut 40 Plasma
Mac Afric Mig 195
Mac Afric Tig 200A
Thermax DC 200
Fulgor Butt Welder
13" Metal Lathe-Milling Machine
Rong Fu 25 Mill
goldwinger
Postby goldwinger » Sun Sep 17, 2017 2:01 pm
Deon
Thank you very much for your help, I will try cutting this out today my fingers are crossed
I will message you and let you know it WORKED GREAT, as i'm sure it will
Thanks again
Ken S.
Arc Pro 4800
PowerMax 45
Mach 3, Sheet Cam
Inkscape, Paint.net
goldwinger
Postby goldwinger » Sun Sep 17, 2017 6:57 pm
Deon
Thanks for trying but it didn't cut well at all
Would be easier if client could accept larger size, but won't
thanks
Arc Pro 4800
PowerMax 45
Mach 3, Sheet Cam
Inkscape, Paint.net
rdj357
Postby rdj357 » Sun Sep 17, 2017 10:41 pm
Here you go, hope this helps. It is far from perfect but should cut. Took me a little over an hour to do - original art was poor resolution and the thing needs a ton of bridging to cut without fallouts and spindly messes. I might have missed some but it's bedtime and tomorrow is a short vacay!
Good luck!
Mess.dxf
Robert Johnson
FourNinety Creations
PlasmaCam 5x10
Snap-n-Cut Mount
PM 65 w/ Mini Machine Torch
Router Attachment/DW611
VCarvePro & Photo VCarve
SpectraCoat Powder Coat System
7'x7'x10' DIY Powder Coat Oven
goldwinger
Postby goldwinger » Fri Sep 29, 2017 11:09 pm
rdj357
I want to Thank you for the help that you did with this piece.
I'm new at this but hope to be able to learn some of the tricks of the trade. (I hope soon)
Again Thank You so much for your help, you don't know how much I appreciate what you did for me.
Goldwinger
Ken S.
Arc Pro 4800
PowerMax 45
Mach 3, Sheet Cam
Inkscape, Paint.net
rdj357
Postby rdj357 » Sat Sep 30, 2017 7:20 am
No problem Ken, hope it helps to see kind of how the process goes for editing and bridging and will get you started in the right direction!
Robert Johnson
PlasmaCam 5x10
Snap-n-Cut Mount
Re: Vader Chiefs Mess
Postby plasmanewbie » Wed Dec 13, 2017 11:44 am
Nice conversion on that one rdj357! I think its awesome how you can determine all the connection points needed and still make it look awesome. Very nice!
rdj357
Postby rdj357 » Wed Dec 13, 2017 2:02 pm
Thanks, it's just practice and luck. Then some more practice and then some practice and also a little bit more practice.... :-) There are many much better than I but I muddle through. :-D
Robert Johnson
PlasmaCam 5x10
Snap-n-Cut Mount
Users browsing this forum: FamilyFab, Google [Bot], wava, wishiwastorching and 19 guests
