Rock grapple for compact tractor
I drew this years ago. I cut one so I know it works. I used a diverter valve and cylinder from Surplus Center. there is a 50" wide model that is nested on a 4x4 sheet and a 60" model that takes a 4x8 sheet. I used 3/8" AR 400 plate. I would up it to 1/2" if you use standard hot rolled plate. assebly needs some round tube and square tube to finish.
- Loyd
Re: Rock grapple for compact tractor
Thank you!
Here are the hydraulic parts I used. the valve is mounted to the tractor to switch the bucket rotate to close the grapple when you press a button to energize the valve.
2x6x1.25 DA HYDRAULIC CYLINDER WOLVERINE WWXT2006-S part # 9-8771-6
12/24 Volt DC 13.2 GPM SAE 8 Solenoid Operated Double Selector Valve part # 9-8602
Very cool. Thanks!
- exapprentice
Hi "schmaus"
Any chance you any pictures of these parts assembled to go with the file you posted
just thought I would ask
Best Regards to all
Exapprentice
(Pete)
10'x5' DIY table / PM 45XP + M/C Torch - Trying to add 4 axis Tube cutting
Exapprentice
(Pete)
I do have one picture but I have never resized a picture before so it may take a little while.
- exapprentice
Hi schmaus
No problem, as I said "just thought I would ask" great if you could
Best Regards to all
Exapprentice
(Pete)
Exapprentice
(Pete)
- Larry83301
Here's an easy way to resize a picture, just load it into PAINT then click on the HOME tab and near the left side you will see the resize option. You can resize by percentage or by pixels, after you get it to the size you want click on FILE and do a SAVE AS so you will still have the original picture also.schmaus wrote:I do have one picture but I have never resized a picture before so it may take a little while.
Thanks Larry! Easier then I thought.
the mounts I made where for John Deere quick attach bucket. It could be easily adapted to skid steer quick attach. I don't have one to reference from.
- Peechy
Great post ! Thank you
Thank you very much for sharing.
right on! Mine served me well for years. Sold the tractor and all attachments to a friend. It is still serving him great.
- kchoghead
is this a skid steer mount or john deere
Sorry i just read through the posts and answered my own question
