Another Firepit
Another Firepit
This isn't my design, I copied the design from someone else, but I did draw this up myself. I quoted it to a customer and figured I draw it up anyway even if they don't order it since I'll probably cut one for myself. I would love if someone could cut this before I do and tell me how it fits together! Designed to be cut from 1/4" thick steel, the slots are 0.27" to provide some clearance. Overall dimensions are around 30" W x 36" L x 12" H. The flat piece that sits in the frame is 8" W x 34.25" L. I think the square holes are for adding a gas setup. It's a neat design because it all slides in place and can easily be taken apart for storage. Here's some pictures of the 3D rendering I put together. You'll need to cut 2 of the sides, 2 of the walls and 1 bottom piece.
What I always do whenever I have pieces fitting together like this is draw up a couple small pieces with slots in them, then test fit the fit and adjust as necessary, just as a tip.
- Gamelord
- 4.5 Star Member
Re: Another Firepit
Nice and clean, thanks for the share.
Re: Another Firepit
I will be trying this out...Thanks for the share
Re: Another Firepit
Thanks for sharing, looks good
Re: Another Firepit
=) I was planning on making the same thing started drawing it too off the sample images they had but never finished
Re: Another Firepit
Is this a break away pit?
Re: Another Firepit
Here's the exploded view
- hdfaster
Re: Another Firepit
Thanks.
Re: Another Firepit
that's awesome! thanks
- tnbndr
Re: Another Firepit
Just looking at the design, what keeps the bottom from tipping and sliding down? I think it needs tabs that fit into slots on the two long sides to prevent that. JMHO
Re: Another Firepit
saw one of these at a flea market a few weeks ago. Thanks
K D Metal Werks
PlasmaCam DHC2
Hypertherm Power Max 45
Hobart Handler 190 Mig
Niagara 3"x 36" Slip Roll 14ga
Driess/ Krumph 4' box & pan brake 16ga
Hossfeld #2 Bender Ridgid 700 threader
Pexto 137-1 16ga. Stomp Shear
MADE IN USA
PlasmaCam DHC2
MADE IN USA
Re: Another Firepit
WOW amazing file thanks for the share
Re: Another Firepit
Has anyone else cut this yet? I just cut it out a couple days ago. I did a test fit and I thought the fit was too loose. I didn't adjust the drawing, I just slightly scaled down the file when loaded into SheetCAM. I think I did 1:24.5 instead of 1:25.4. I should have just kept it, the fit was too tight and once it did go together, it's a pain getting it apart. I just have it setup as a display in my showroom, so no big deal. As for the center piece falling down, it actually fits pretty nicely. I think the angles are steep enough to keep it centered pretty well. You have to push down pretty hard on one side to get it to slide off-center at all.
So I'm just curious if anyone cut the file as-is and if it went together smoothly or not?
