It is currently Mon Sep 24, 2018 7:48 am
New plasma table arrived
krymis
Postby krymis » Fri Aug 25, 2017 10:05 am
Well I am picking up my table today. After1pm I will be putting it together. Getting very excited. Any pointers as I get started? I got a DHC2 with all upgraded software, Plasmacam computer, Hypertherm powermax65 cutter, Plasmacam router kit, Plasmacam engraver kit, HF air dryer. Anything I am missing?
Re: New plasma table arrived
Postby jimcolt » Fri Aug 25, 2017 12:29 pm
Good machines, excellent software. Now it is learning curve time! Join the Plasmacam Owners community using your machine serial number.....great help there from many users. Jim Colt Hypertherm
krymis
Postby krymis » Fri Aug 25, 2017 10:51 pm
jim,
thank you for replying. i actually tried to friend you on FB after seeing some of your video instruction on youtube. You give some great adviseand instruction. I joined the community at plasmacam also.
Postby jimcolt » Sat Aug 26, 2017 9:09 am
I keep Facebook for just family and close friends.....everything else online is all business! Good luck and have fun with the Plasmacam. Jim
krymis
Postby krymis » Sat Aug 26, 2017 3:22 pm
Well guys I just took the time to hook up the torch control wires as per the instructions on the manual. Pretty scary to open a new plasma cutter and start cutting into the wiring. So hopefully the electrician checks it out and it is all good. Up next is to clean the final spot for the machine to sit and get the computer in a cabinet and cutter mounted in the machine
krymis
Postby krymis » Sun Aug 27, 2017 9:48 pm
so today i got the area where the machine's final spot will be. I have lights and plasma cutter electric being ran tomorrow. Then it is just setting the machine in place and hooking up the downdraft.
krymis
Postby krymis » Tue Aug 29, 2017 8:54 am
Hypertherm hooked up, plasmacam put together, and plasmacam in final location for now. Last night added lights and 220v receptacle Still need computer enclosure, downdraft setup, and white insulated metal panels on walls
racerx1194
Postby racerx1194 » Tue Aug 29, 2017 4:33 pm
she up and thumping yet
krymis
Postby krymis » Wed Aug 30, 2017 9:41 am
not yet. I got to plumb the HF air dryer tonight, finish the plug on the other end of the 220v line, put in grounding rod, and wait for my fan for the down draft. I am moving the computer out tonight to start getting the table moving around.
steel 35
Postby steel 35 » Wed Aug 30, 2017 10:34 am
I would add the motor guard M 26 filter between the air dryer and the Plasma cutter! Having fun yet :mrgreen:
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
krymis
Postby krymis » Thu Aug 31, 2017 10:55 am
I have the M60 paper filter at the plasma. Do you think that is enough?
I ran movement tests last night. I used the control box to shuttle and jog around the table. I then used the butterfly program to move the table solely by the computer. I am happy with the movement. Now to setup the settings for the table and plasma, the router, and the scriber.
steel 35
Postby steel 35 » Thu Aug 31, 2017 2:46 pm
That looks like the one :D
PPL HDG 4X8
Hyp 65 duramax's
Uzaree
Postby Uzaree » Sun Sep 03, 2017 12:31 pm
I have owned a plasma cam for 10 years. I maybe spent $1200 through the years in maintenance, new bearing, new grate etc. solid machine. Of that $1200 one year spent $800 and I built a different grate system and replaced all the bearings and bought a extra Z axis motor for a spare. So you should get great service from this machine.
I just stopped using it only because I bought a laser but I still have it.
krymis
Postby krymis » Sun Sep 03, 2017 10:10 pm
guys i am up and running. made my first parts tonight. thank you all for the help.
sawdust1
Postby sawdust1 » Tue Sep 12, 2017 9:54 pm
Uzaree or anyone else with a laser... I have a diy plasma water table, the water catches the heat/smoke after the flame cuts the metal. The flame is really quite short. On a laser system what catches the light? This may be a dumb question but does the light beam not stay coherent? On a downdraft table with no water where does the beam become too weak to cut?
rdj357
Postby rdj357 » Wed Sep 13, 2017 10:52 am
What I have is a co2 laser and it is neither powerful enough nor set up to cut metal BUT I can tell you that once the beam is significantly out of focus it is relatively harmless. It is absorbed by most surfaces and the heat dissipates.
Robert Johnson
Learn Plasmacam Website
Learn Plasmacam on Facebook
Learn Plasmacam on YouTube
Return to “PlasmaCam”
