Jeep Grill Firepit DXF Design
motoguy
Re: Jeep Grill Firepit
Post by motoguy »
I charged $175 out of 3/16". Found several online for $250. I sold the half dozen or so I cut, haven't cut any more since. I would need to recheck, and see if that pricing still holds. They were one of the first items I cut and sold.
ETA: $215 with steel price update.
Metal teacher
Post by Metal teacher »
awesome thanks for sharing
kennye
Post by kennye »
Thanks for sharing
JUSTWHATEVER
Post by JUSTWHATEVER »
Awesome!!!
Gogogadget62
Post by Gogogadget62 »
Thanks for sharing your file ,looking forward to cutting this jeep design
Dan Gauthier
5x10 Samson
Miller 185 wire feeder
600 Hypertherm
45 Hypertherm
85 Hypertherm
40 ton press and dies
powder coating
80 gallon DeVAIR compressor 5Hp
rickjamesbish
Post by rickjamesbish »
I found the 3/16" to be too heavy. Its a break down so obviously meant to be portable. Being jeep shaped its likely geared at off roaders. Granted most JK owners are mall crawlers and will likely use this grill the one time a year they accidentally go off road ;) On the other hand I wheel every weekend so the lighter the better. I did my own personal one in 1/8" and used a few of the longer cutouts tacked under the bottom to prevent warping. I think even a smaller size would be optimal for someone who really off roads regularly so I will try that next.
Jaked937
Post by Jaked937 »
rickjamesbish wrote:I found the 3/16" to be too heavy. Its a break down so obviously meant to be portable. Being jeep shaped its likely geared at off roaders. Granted most JK owners are mall crawlers and will likely use this grill the one time a year they accidentally go off road ;) On the other hand I wheel every weekend so the lighter the better. I did my own personal one in 1/8" and used a few of the longer cutouts tacked under the bottom to prevent warping. I think even a smaller size would be optimal for someone who really off roads regularly so I will try that next.
Have you tried yours out? My steel yard has a bunch of 1/8" for cheap right now, I was thinking about buying a bunch and trying to knock some out.
Anyone else using 1/8" or is 3/16" the norm?
rickjamesbish
My own personal one ends up getting sold every time I make it ..LOL .. so I have not had the chance to burn anything in it yet but have received no complaints on the ones I have sold. Im actually going to cut another one this weekend and scale it down in size a little.
BILLETMAN
Post by BILLETMAN »
thank you for sharing !!!!
david jordan
Post by david jordan »
this is neat, thank you.
PlasmaCam DHC 2 4 X 4 table
Powermax 65
400amp mig welder with dc tig
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Sothbend, 5C collets
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Paint Chip
Post by Paint Chip »
Thanks very much!! No.2 son and I are Jeep enthusiasts. He will live this for Xmas this year.
PPLLC 4X8 table w 620 ox steppers on 5 axes
Bladerunner CandCNC w/DTHC II
Hypertherm PM85
montanarose
Post by montanarose »
very nice !! what gauge of metal do you recommend for the grill so it doesn't warp with the heat ??
motoguy
Post by motoguy »
montanarose wrote:very nice !! what gauge of metal do you recommend for the grill so it doesn't warp with the heat ??
I use at least 3/16"
ConcFab
Post by ConcFab »
Thank you! I am donating a fire pit to the Maine Warrior Salute off-road fundraiser in August. This is much better than what I had planned. I am sure it will raise a lot of money for a good cause!
awkjesse
Post by awkjesse »
This is awesome!!
montanarose
Thank you very much for your time :)
montanarose
Hello,, to cook on the grate is there any kind of special spray you apply first?? Thanks ;)
izzyscages
Post by izzyscages »
I'm a little slow today... are there two different versions? One with legs, one without?
jabtronic
Post by jabtronic »
Is it just me or did anybody notice the slots and tabs in the dxf posted don't link up with each other? I'm using CorelDraw I can't open the original PCM file.
The only slots that seem the correct size are the vertical ones on the front and back panels.
Something to keep in mind
EDIT: Another small issue is the tabs on the bottom plate and the grill are not perfectly inline with each opposite side but the difference is so minimal (0.32mm out) it shouldn't make a difference unless your slot tolerances are really tight.
Kitch940
Post by Kitch940 »
jabtronic wrote:Is it just me or did anybody notice the slots and tabs in the dxf posted don't link up with each other? I'm using CorelDraw I can't open the original PCM file.
Yes I had to go through and redo all the tabs and slots and align them all up. The original file couldn't have worked the way it was. Still was a good start though!
nicalvarado
Post by nicalvarado »
Looks great!
Uzaree
Post by Uzaree »
Nice, I like that!
Welding14
Post by Welding14 »
Thanks looks good
Jwagnon89
Post by Jwagnon89 »
Does anyone want to share their revised version of this using 11 gauge? Thanks!
Dynatorch 5x10 Super B with water table
Thermal Dynamics A80
Miller 250x
Protools 105 tubing bender
JD2 beast notcher
recon44095
Post by recon44095 »
This one cuts good for me
4X4 Plasma Cam DHC2
w/down draft Hypertherm 45
3x4x6 home made powder coating oven
