Cutting metal Mesh
Cutting metal Mesh
Did a search but did not find an answer. Was wondering if you can CNC Cut metal Mesh with the small holes in it or little squares. My thinking is probably no but wanted to see if anyone here has tried and hiw was the result?
Arclight 5x5 table
Delta 3 CandCNC controller
Hypertherm PM 85
Linux computer
Solid edge 3D
SheetCam
Inkscape
Millermatic 211
www.ceeplasma.com
Hypertherm PM 85
Linux computer
Solid edge 3D
SheetCam
Inkscape
Millermatic 211
www.ceeplasma.com
Re: Cutting metal Mesh
Haven't done it personally, but I know there is a setting on the PowerMax for it.
I've cut .25 perf plate. It was 16 gauge stainless. Set your PM 85 for interrupted cutting and follow book specs. I used a small piece of scrap if the pierce was directly over a hole.
LDR 5x10
Awesome thank you! I'll get some scrap and see how it goes !
Arclight 5x5 table
Hypertherm PM 85
Linux computer
Solid edge 3D
SheetCam
Inkscape
Millermatic 211
www.ceeplasma.com
Hypertherm PM 85
Linux computer
Solid edge 3D
SheetCam
Inkscape
Millermatic 211
www.ceeplasma.com
I cut expanded metal on mine quite a bit. Just switch your plasma cutter to the interrupted cut setting and turn off dthc.
Powermax mode switch
