It is currently Tue Jul 17, 2018 5:44 am
Fathers Day - Dad's Garage Sign
DXF Art Sharing Forum is for sharing dxf, plt, or any other vector file for plasma cutting. Browse what others have posted or post some DXF art files of your own.
rbarabe
Re: Fathers Day - Dad's Garage Sign
Postby rbarabe » Mon Oct 03, 2016 9:33 pm
Thanks for sharing!
BILLETMAN
Postby BILLETMAN » Thu Oct 06, 2016 5:15 pm
very cool thank you!
Metal teacher
Postby Metal teacher » Wed May 31, 2017 8:54 am
cool thanks
Jhva
Postby Jhva » Sun Jun 04, 2017 11:11 pm
Awesome file(s)! Thanks! I combined and modified files from PS (93 HD Ultra Glide from 2016) to make this to cut on my cnc router. 24" H x 22" W 1/2" 9 ply Baltic Birch.
Probotix Meteor CNC Router
Vectric VCarve Pro Software
Postby Larry83301 » Mon Jun 05, 2017 10:17 am
Very nice!
beck77
Postby beck77 » Mon Jun 05, 2017 12:54 pm
thanks
BILLETMAN
Postby BILLETMAN » Tue Jun 06, 2017 1:42 pm
VERY NICE THANK YOU
seajinx
Postby seajinx » Fri Jun 16, 2017 8:33 am
Beautiful piece of work Jason, thanks for sharing.
Fcapt10
Postby Fcapt10 » Tue Aug 15, 2017 12:51 pm
Any idea why it shows up as two images of the sign with different cut lines? I can only use this dxf file by putting it directly into sheetcam and that wont let me edit anything on the drawing.
Postby acourtjester » Tue Aug 15, 2017 1:09 pm
SheetCam will allow to remove some things by changing them to different layer editing should be done with a drawing program.
Everlast PM 256 tig
Postby Larry83301 » Tue Aug 15, 2017 1:56 pm
Fcapt10 wrote:Any idea why it shows up as two images of the sign with different cut lines? I can only use this dxf file by putting it directly into sheetcam and that wont let me edit anything on the drawing.
The two drawings are for people that have different needs, some want to make a small piece with detail and some want a large one but want to use a small kerf to retain the detail that the original picture had. For this reason you will notice that one part has a detail line that has no thickness and the other part has that same line as a complete loop so that it can be followed around on the inside and after the drop is removed that detail will look just like the other part. Many of the members have different ways of cutting parts, some with plasma @.06 kerf or @.035 and others can cut with kerfs as small as .005 or even just a knife edge. Then again others don't cut the parts out they BURN them out with lasers or cut into the surface with routers so a drawing that one person uses may not be work well for the next person, but the other style may be right for them. Most of us just remove the one we are not using and proceed from there.
If you have some files that have both styles in them and you need one of them removed just PM me with the file you want changed and I'll give you a hand, OK. :D
Postby acourtjester » Tue Aug 15, 2017 2:13 pm
Inkscape is a program that you can learn to edit files to change by removing or adding things you want. As above he remove the model A and installed a bike. you could remove Dad and put Joe's if you wanted to. Here is a simple example of what I mean.
Everlast PM 256 tig
profabwelding
Postby profabwelding » Thu Aug 31, 2017 10:26 pm
Thank you for the design! I will be trying to use a different car and name! Great work!
profabwelding
Postby profabwelding » Thu Aug 31, 2017 10:42 pm
How did you make the parts inside the car "loop" or "bubble"? I am trying to do that with one of my drawings and my lines wont stay parallell
Postby acourtjester » Fri Sep 01, 2017 12:09 pm
I will help if you say what software you are using and attach an image with description
Everlast PM 256 tig
Mr. Fixit
Postby Mr. Fixit » Tue Apr 17, 2018 8:39 pm
Awesome file.. Thank you..
MrsSavage
Postby MrsSavage » Fri Jun 08, 2018 11:08 am
Thank you
Jfile
Postby Jfile » Sat Jun 09, 2018 2:02 pm
Great looking sign. Thank you so much. I'm just getting started so I hope I can get my table set up in time to make this one before Father's Day! Jeff
Buzzard Gut
Postby Buzzard Gut » Tue Jun 12, 2018 3:11 pm
Nice, Thanks Jason.
The older I get, The better it was!
Users browsing this forum: No registered users and 14 guests
