TATTERED AMERICAN FLAG
burntcustoms
Re: TATTERED AMERICAN FLAG
Post by burntcustoms »
is there a recommended thickness for the steel ?
Hillbilly Stills
Post by Hillbilly Stills »
I use 16 gauge for small ones.
TruCut 5x10
Victor Plasma
Thermal Dynamics
Sheet Cam
Rhino3d
Bobcad
Beevo
Post by Beevo »
THANKS NEED THESE IN EVERY SCHOOL
Craig Rumble
Post by Craig Rumble »
I downloaded the DXF for this, however, all the lettering came into sheet cam with two start points per letter. Anybody else run into this? and what was the fix??
JHART02
Post by JHART02 »
Thank you so much! Great detail!! Thanks for sharing
metaltrends
Post by metaltrends »
Hi, I am new to this forum and I love it! Does anyone here happen to have any Canadian Flags, Uk Flags etc??
mkeilman81
Post by mkeilman81 »
Would anyone happen to have this file with the 2nd amendment on it.
Pendleton Racing
Post by Pendleton Racing »
Here is a version I cleaned up a bit, Haven't cut it out yet though.
Tatteredflag.dxf
DaveRad
Post by DaveRad »
Just as a heads up, those sharp points can injure someone (yeah, ask me how I know) anyways I rounded all the flag points. But this is the most awesome flag when all done!!
justfishmetalart
Post by justfishmetalart »
Awesome ,Thanks
Ray P Mehl
Post by Ray P Mehl »
Thanks for the share. here it is cut out.
weldingchick2000
Post by weldingchick2000 »
very cool. thank you
tothwelding
Post by tothwelding »
heres one ive cut
TATTERED FLAG NEW.dxf
Cottonwood Bottom
Post by Cottonwood Bottom »
Thank you!
Searchman
Post by Searchman »
All American Share. Thanks
Jearnest13
Post by Jearnest13 »
Fab Shop
Post by Fab Shop »
Thanks for the share!
spboller
Post by spboller »
Okay, I am using a Viper Cut 30 amp plasma cutter with a .8 nozzle 90psi cutting at 100 ipm. Will this file work to cut with what I have, or is it more meant for a laser cutter?
Shawn P Boller
S and L Weld Services, LLC
spboller wrote: Fri Apr 12, 2019 7:20 am Okay, I am using a Viper Cut 30 amp plasma cutter with a .8 nozzle 90psi cutting at 100 ipm. Will this file work to cut with what I have, or is it more meant for a laser cutter?
Yes this will work with what you have, most if not all these guys are cutting this with plasma.
DaveRad
Post by DaveRad »
I got this from here proballz03
TatteredConfederateFlag.dxf
bikerman883
Post by bikerman883 »
I am having a problem doing the cut lines on the flag, it only wants to do small lines when o go to click on a cut line. How can I fix this?
ETCWeld
Post by ETCWeld »
rickjamesbish wrote: Wed Jan 18, 2017 9:42 am If this video works https://youtu.be/97sKopToMCE you can see as I remove masking how I do mine. Disposable vinyl sounds like a plan.. depending on cost.
thanks for the files and thank you for the video :Like
Metaspec
Post by Metaspec »
Very nice flag thanks for the share
vertexner
Post by vertexner »
when ever i run this program it stops cutting around step 2460ish some help would be greatly appreciated
bradcook010
Post by bradcook010 »
Are you guys welding brackets on the back of the flags? Or how do you tell your customers to mount them?
