LED light strips
LED light strips
I know a lot of you use the led light strips that you can get on ebay and I also know the adhesive is hit or miss on the. My question is how do you make sure the lights are going to stay?
Re: LED light strips
I'm a big fan of these LED Modules most also have better double sided foam tape on them compared to the cheaper rolls.. I rivet them when possible.
Mind to share the source on where you get these? I know I can find some that LOOK like these, lol, but if you have a supplier with reliable product, that would be good to know. Thanks!limited405 wrote:I'm a big fan of these LED Modules most also have better double sided foam tape on them compared to the cheaper rolls.. I rivet them when possible.
I get similar on Amazon and have had great luck with them.
Derek
Precision Plasma LD 4x8
HT PM 45
HT PM 45
- _Ogre
we have this 3m adhesion promoter around for fastening body kits on cars, good for 100 mph
you definitely want to stick the strip in the correct spot the first time
i prefer to use the grey tape if i have a choice but the led strips come with white tape (not as durable)
my 3rd brake light (1 meter led light strip) has been in place for 5 years without an edge lifting
anytime i use adhesive tape i use the adhesion promoter
google '3m adhesion promoter' you can find it most anywhere, even walmart carries it
an ogre smiley how cool!
Let flexible waterproof RGB LED strips I purchased from Amazon have started falling off (the tape is failing). I guess I'll need to remove the stock tape and apply with good 3M stuff, or find LEDs with quality adhesive.
- Nacs Fab
I actually cover my led strips with clear Gorilla Tape. After I stick them inside a sign, I tape over them and they stay!
G540 with LCTHC by candcnc
all built... by me...
Anyone had any Experience just using Hot Glue?
- rdj357
signlightingworld.com - they have great modules and they come with 3m tape. Good stuff!
Robert Johnson
Learn Plasmacam Workshops
Learn Plasmacam on Facebook
Learn Plasmacam on YouTube
