American Force Truck Wheel
i have a Drawing for some custom wheels i need help with i cant seem to get them right thanks.
Re: Help needed on drawing
not sure what your after, not sure how much detail hope this helps. I left the writing out didn't know if you wanted it in.
should be ok but check and clean up before cutting
Hi Alan
What software did you use to trace that wheel??
hi
i did the wheel by hand using a mixture of corel draw and solid edge.
wasn't possible to get good trace thro corel so just made circles and drew key components then circular pattern tool.
pretty simple when you break it down as its only geometric shapes.
I tweaked it this morning and sorted some issues, even included the lettering
Thanks for the reply nice work I use Inkscape but images like that you cannot do a quick trace, wanted to see if there was a better way.
I'm to cheap to buy those expensive packages.
- Larry83301
acourtjester wrote:Thanks for the reply nice work I use Inkscape but images like that you cannot do a quick trace, wanted to see if there was a better way.
If you look around you can get many software programs reasonable. I just looked and found " Corel DRAW Home and Student Suite X7 (3-Users)" for less than $40. Not bad if you use less then 3 computers. Other software can be found for a reasonable price if you look around.
I be looking around
whoops not to many students my age well Amazon has home and student for $47. may need to jump on that.
I bought it because solid edge wasn't doing it for me in the arty area, sure its great for structural parts but anything else Corel draw for me.
I've been self taught with Corel over many hours because I needed answers I couldn't find on the net, like anything the more you use it the more proficient you become with your package and then nothing really phases you. sure I could spend a few more hours tweaking bits and pieces on any drawing that I convert for people, but once people see what can be done then maybe it'll inspire them to have a go at converting images, after all at the end of the day its not that hard once you learn the programme
Re: American Force Truck Wheel
WOW ALAN, killer work on this one!
Thanksplasmapros wrote:WOW ALAN, killer work on this one!
Alan
Than I got a question.How does Corel draw home and student X7 compare with Coreldraw x7? education?
- runninwild400
Make sure it will save as a dxf, I have a home and student version and it will not save as a dxf.
Metal-Magic
Metal-Magic
Thanks that's kind of what I thought.
