Jeep Grill Firepit DXF Design
scharesmetalworks
Re: Jeep Grill Firepit
Post by scharesmetalworks »
Thanks for posting! I hope I remember to cut this with free time.
Corinne
j.tractor
Post by j.tractor »
Thanks for posting. Cant wait to cut out. What is the Grilling part cut from? Stainless? or just HR? I wouldn't think you would want to paint this part. What are people doing?
motoguy
Post by motoguy »
All 3/16 HR on mine.
d2day
Post by d2day »
Great file, works flawlessly..thank you for the share
Mach 3
SheetCam
Corel x5 / Version 12/ Version 7
ArtCam 7.0
CNC Router
ULS Laser
4x4 Plasma Table/Hand Built
HyperTherm PowerMax 45
Cut Shop Software
LCTHC
whiskeymike
Post by whiskeymike »
Anyone remember the size sheet required to do the larger versions? And did you use 4ft, 8ft or 10 ft sheets? I'm going to order some sheets to try this out. I normally order 10ft sheets, sheared in half so I can move them around easier. On small pieces, the waste in minimal, but worried with the larger pieces, it might be worth dealing with the continuous larger sheet to reduce waste.
motoguy
Post by motoguy »
This is a pair of Jeep pits nested into a 4x8 sheet (with some small parts thrown in for scrap reduction).
Eta: I just noticed there is still some open area in the middle, between the fire pit side panels. I ended up nesting some stuff in there as well, before I cut it.
AIRFLOWKID
Post by AIRFLOWKID »
Thanks so much!
DRAGONDADDY
Post by DRAGONDADDY »
THANK YOU FOR SHARING!
Jamie:-)
Bigdogbro1
Post by Bigdogbro1 »
Thanks for sharing! Many combinations and styles to choose from...great work!
stevo007
Post by stevo007 »
That is fantastic love the design and very unique too - Can be used as a beverage cooler too throw some ice in and stack in those cool ones ;)
thatboystevo
Post by thatboystevo »
Im am going to cut one of these out finally!
1 Thanks for the share !
2 - how Do I go about bending the sides with no access to a press ? Thanks in advance
Stevo
radicalrescue
Post by radicalrescue »
thatboystevo wrote:Im am going to cut one of these out finally!
Stevo
hay stevo u can bend them on the cut line just clamp it to the bench an u can push it down till it get to the spot were u want it ..but if ur a light weight like me u might need to make a leverage bar to clamp to it..
art&fire
Post by art&fire »
Nice design. Very cool indeed.
Can I use the basic front view for my
upcoming advertising plans ?
I don’t wanna butt-heads with the original artist...?
There would be some changes !!! OK ?
TorchMate 2x4
Powermax 65
AutoCad LT
Photo Shop
Zeke
Post by Zeke »
THANKS FOR THE POST
nick d
Post by nick d »
im new to this whole thing and cant seem access anything ....but thanks for all ya do this jeep grill is badass
SHAWNELIASON
Post by SHAWNELIASON »
motoguy wrote:This is a pair of Jeep pits nested into a 4x8 sheet (with some small parts thrown in for scrap reduction).
Do you have a dxf of this? with or without the small parts.. My machine is setup on an x long axis and this would work perfect. I cant seem to, due to limited cad experience, get a dxf here where I can seperate and nest the parts.
Zeke
Post by Zeke »
thanks
hinesigns
Post by hinesigns »
I have made many of these this past summer. The first one had a very loose grill on it so I drilled 2 more holes in the tabs sticking out, kitty corner & put 2 more snap pins in the top. No more loose grill.
donnieplasma
Post by donnieplasma »
any idea how long my membership takes to update? i love this and cant wait to cut one out once i get access to it!
donnieplasma
thanks so much for posting! cutting one out tomorrow!!!
danrock666
Post by danrock666 »
thank you very much for the file
cody14869
Post by cody14869 »
Thanks for the share! Awesome
Cody
Arclight CNC 4x8 - Hypertherm Powermax 65
rickjamesbish
Post by rickjamesbish »
So this grill is basically a full 4x4 3/16" sheet. I'm a jeep owner and wheel evwry weekend. On top of extra driveshaft, jack, extra fuel, compressor, etc.. this is a bit on the heavy side for carrying offroad. Anyone have dxf for one in 1/8 " ?
Aandbfabrication
Post by Aandbfabrication »
Does anyone have a DXF of a Toyota FJ Grill Firepit?
JB Designs
Post by JB Designs »
Thank You for the share!! Awesome design. I'm just starting out in this business. Is there any chance anyone could tell me what they would charge for this pit.
Thank You
JB Designz
