3/16 dragon with wings
harrymorley
Post by harrymorley »
This is a pic of the large dragon I make. I have the file in pcm if anyone is interested
HammerDownJustin
Re: 3/16 dragon with wings
Post by HammerDownJustin »
That is very nice
Miller 251 Mig
CNCCAJUN
Post by CNCCAJUN »
Any chance you can post it as a DFX file?
That is really a fine looking dragon . . . :D
Thanks in advance,
Steve :D
Dynatorch 4X4 XLS
PowerMAX 85
Baton Rouge, Louisiana
harrymorley
my software doesnt have an export as dxf option. sorry
harrymorley
my software doesnt have an export as dxf option. sorry . Ill post it as pcm ..maybe someone will load it and put it back here as dxf
dragon with flames and wings three sixteenths.pcm
DieselMonkey
Post by DieselMonkey »
Heres the DXF, HarryMorley what is your kerf offset set at?
dragon with flames and wings three sixteenths.dxf
Few problems in life can't be solved with the generous application of a cutting torch and a taco truck.... or something like that.....
Craig
Post by Craig »
Nice lookin dragon Harry. Craig Johnson
Craig Johnson
oldcrow
Post by oldcrow »
Very nice, thanks for the share.
harrymorley
kerf offset .067 .. dont really know if thats correct but it works well
CNCCAJUN
Post by CNCCAJUN »
Downloaded the DXF . . .
Why are most of the parts drawn with double lines? :?
Steve in Louisiana
Dynatorch 4X4 XLS
PowerMAX 85
harrymorley
could it be youre seeing cut paths too
CNCCAJUN
Post by CNCCAJUN »
harrymorley wrote:could it be youre seeing cut paths too
I very well be . . . I am trying to learn as much as I can. . . .
When open I see 99% of the parts or double line, like offset looks in AutoCAD . . .
Will not have a table ordered for about a month.
Dynatorch 4X4 XLS
PowerMAX 85
MetalTorcher
Post by MetalTorcher »
Hope you don't mind Harry but I cleaned up your original file to get rid of the cut paths. Hopefully everyone won't be seeing double now :shock:
Jason Lyon
PlasmaCAM DHC2
Advanced DesignEdge
Hypertherm Powermax 1000
Duramax mini torch with Snap n Cut
Everlast PowerMTS 251si
Torturing metal since 2014
harrymorley
Re: 3/16 dragon with wings..asssembly insts
here are the assembly instructions for the 3/16 dragon.
Dragon assembly guide.pdf
CNCCAJUN
Post by CNCCAJUN »
harrymorley wrote:here are the assembly instructions for the 3/16 dragon.
Dynatorch 4X4 XLS
PowerMAX 85
MetalheadRK
Post by MetalheadRK »
This is amazing!
4x4 PlasmaCam
Hypertherm 45
Eastwood 175 MIG welder
solomanb
Post by solomanb »
Thanks for the file and assembly instructions
Solomanb
wickedpig
Post by wickedpig »
thank you for the file
Bradley
Post by Bradley »
This is really fantastic. Thanks for sharing
Brew Worx
Post by Brew Worx »
Wow. Great work.
Brew Worx.
Blue Frog Metal Works
Chicagoland
Arclight 4800 :D :D
Hypertherm 45
4 inch tube cutter
Mach 3, SheetCAM, Solid Edge 2D, Solid Works 3D, CREO, Inkscape, and a few cobb webs
MIFab
Post by MIFab »
Now is there a quick way to reduce the slots for say 14g or 11g ?
Armotorsport
Post by Armotorsport »
cheers I must give that a try
covingtoncg
Post by covingtoncg »
This look incredible. Thanks to everyone who took the time to make this a great project to try!!
Vanquish
Post by Vanquish »
Wow. What a great file. Thanks for sharing. The kids will like this.
Vanquish
Post by Vanquish »
Picture shows dragon with wings. PDF no wings. Is there another PDF or is it easy to apply wings?
