It is currently Mon Sep 24, 2018 7:44 am
A120 problem
OTHill
A120 problem
Postby OTHill » Wed Nov 02, 2016 12:41 am
Hi.I bought a used table with A 120 TD plasma.Had to change from 3 phase to single phase.went by the book with the jumper bars and changed the switch to low voltage.Can't get it to cut now has a flashing red code and a flashing green 65 code.Checked input voltage and it's at 230V.Don't know whats wrong.
Brand X
Re: A120 problem
Postby Brand X » Wed Nov 02, 2016 9:14 am
Did you also tape back/disconnect the red input wire? My A120 was configured for single phase from the factory.. (Three wire cord too). The 82(A-60 now) I just picked up new in box was a 460 volt three phase configured machine from the factory. Just the switch to low voltage, and the buse bar jumper installed to the L2-L3 contacts on the side of the contactor that has the Jumper wire going to L1-L4. That is all there is to hook up for single phase.
OTHill
Re: A120 problem
Postby OTHill » Wed Nov 02, 2016 10:49 am
Mine has 2 copper buss bars to install so each bar gets a 120 line is that right?
Brand X
Re: A120 problem
Postby Brand X » Wed Nov 02, 2016 7:24 pm
It been a while since I had the A-120 victor, but that one came setup for Single phase, from the cord on forward.. Only a 3 wire cord, so I did not have to mess with any Jumpers on that one. You are probably correct in that it uses a different buse setup over the A-60..
Looks like it...but the link does not work here.. Service manual shows it very clear. Might have to call victor on this one..
http://victortechnologies.com/IM_Upload ... al_(0-4988)_Dec2013.pdf
OTHill
Re: A120 problem
Postby OTHill » Wed Nov 02, 2016 10:39 pm
Thanks Brandx.
Hillbilly Stills
Re: A120 problem
Postby Hillbilly Stills » Fri Apr 28, 2017 8:07 am
are You guys happy with your Thermal dynamics cutter? This is the first one I have ever owned. used it for about 8 months. Yesterday it quite working. Called Victor and they had me run through several test. Bottom line I have to send it to service center to be repaired. Do any of you own a second machine just encase it goes down on you?
TruCut 5x10
Victor Plasma
Thermal Dynamics
Sheet Cam
Rhino3d
Bobcad
Hillbilly Stills
Re: A120 problem
Postby Hillbilly Stills » Fri Apr 28, 2017 8:12 am
is it common to have problems with the Thermal dynamics victor a120?
TruCut 5x10
Victor Plasma
Thermal Dynamics
Sheet Cam
Rhino3d
Bobcad
Return to “Thermal Dynamics Plasma Cutters”
