Beat up copper look
Beat up copper look
Has anyone ever done anything like this? Looking for ideas on paint options.
- little blue choo
Re: Beat up copper look
I get a similar look by using Copper FX as a base and then misting Pewter FX over it and let sit until the color darkens to where I want it. It will cause the copper FX to turn brownish red. I also get a similar look with some of their other products like Rust FX.
Rick
Rick
Rick
Arclight 9600 4x8 table
Is this on metal with mill scale or do you use colled rolled?
- little blue choo
Use only cold rolled, soak in muriatic acid to remove dross and clean, then polish with 120 grit flap disc. The add your patina.
Rick
Rick
Rick
I'm glad you brought up the acid bath. What do you use for a tub and how long will the muriatic hold its potency? Grinding slag is too time consuming and adds a ton of debris to find its way to my paint.
- little blue choo
I use a DEE ZEE tool storage box part number 6537P. You can find it on Amazon for $99 or less. It is 40' x 28' x 18' The inside is a little smaller. I cut one piece that's 36' x 20' and it fits with room to spare. It has a hinged lid with a rubber seal that keeps the smell in. The lid is also made to be locked with a pad lock. I mix my acid 50/50. I buy a 5 gallon bucket for $30 and add to 5 gallons of water. My first batch lasted a year. This batch is now 2 months old and working as good as it did the first day and I use it daily. Hope this helped.wlockwood23 wrote:I'm glad you brought up the acid bath. What do you use for a tub and how long will the muriatic hold its potency? Grinding slag is too time consuming and adds a ton of debris to find its way to my paint.
Rick
Rick
- tnbndr
Impressive, that tank is bigger than my shop!!!It is 40' x 28' x 18' The inside is a little smaller.
I only get this look when I need it to be smooth and shiny. I would use Copper FX from SteelFX and have the metal a little "disressed" and wait a bit longer before rinsing. I use cold rolled as well.
- steelfx
Great Answer Above:
Unread post by littlefatbuddy » Sat Jun 25, 2016 6:26 pm
"I would use Copper FX from SteelFX and have the metal a little "distressed" and wait a bit longer before rinsing. I use cold rolled as well."
(from Bill)...RUST F/X™ is also a good choice, but the real "look" in the image is from distressing the steel prior to adding a patina. I'd consider using a matte clear after the patina & you'll be home free!
Bill
Bill
If you are soaking and muriatic for the dross anyway, it seems to me it doesn't matter if you start with cold rolled or hot rolled. The muriatic attic acid will remove the mill scale from the hot rolled just as easy as it removes the dross from the cold rolled. Isn't this correct?little blue choo wrote:Use only cold rolled, soak in muriatic acid to remove dross and clean, then polish with 120 grit flap disc. The add your patina.
Rick
- steelfx
Thanks Bill! I received my super starter kit today. I am looking forward to learning how to use it!
- steelfx
- little blue choo
I use the cold rolled because it is cheaper and it seams to clean up a lot quicker with less effort and time is money my friend.motoguy wrote:If you are soaking and muriatic for the dross anyway, it seems to me it doesn't matter if you start with cold rolled or hot rolled. The muriatic attic acid will remove the mill scale from the hot rolled just as easy as it removes the dross from the cold rolled. Isn't this correct?little blue choo wrote:Use only cold rolled, soak in muriatic acid to remove dross and clean, then polish with 120 grit flap disc. The add your patina.
Rick
Rick
Rick
I would love to:
1) find CR available locally
2) cheaper than HR!
Color me green with envy. At some point I want to be burning through enough to justify a delivery...then I can get CR! Lol
2) cheaper than HR!
