With Mach3 is there a way to use dual monitors with one for the tool path and the other for the rest of the functions.
This would be a big help to see the tool path on large monitor by it self.
Ron
Dual Monitors and Mach3
- rons
4x8 Home made with PPL Gantry
Bladder water table
Candcnc EtherCut + DTHCIV
Hypertherm PM 65 machine
Sheetcam, Mach 3
Corel DrawX7
TurboCad 2015
211 Miller Mig
Ingersoll Rand 7.5 hp 80 gal
Harbor Ref. Dryer
Bladder water table
Sheetcam, Mach 3
Corel DrawX7
TurboCad 2015
211 Miller Mig
Harbor Ref. Dryer
- tnbndr
Re: Dual Monitors and Mach3
Pretty sure that is just a windows thing.
Set up for two screens in Control Panel and follow prompts or play around. I used to run multiple monitors when working doing CAD work but its been several years.
MACH has no way to run two screens on two monitors . The screens are also not re sizable (everything gets stretched). Only thing you can do is use MACHScreen (application and build a new page and put it in the tabs to have a large toolpath object on an alternate screen but you will need to switch to that tab. There are special buttons and LED's on our screens so if you need one you need to copy the object and paste it . I can't think of a way to have two monitors with two different screens both running from MACH. The TAB lets you build a "flyout" and it will make the screen wider so if you had a larger screen then you could build a custom fly-out (page 50) to have a big toolpath but is still just one screen that gets put on one screen. You can put two monitors on one video and set them up to be combined so it makes a really wide single screen but it has a black post on the middle .rons wrote:With Mach3 is there a way to use dual monitors with one for the tool path and the other for the rest of the functions.
Ron
- rons
Dual monitors and a full tool path on a 21" all by itself that is 1:1 scale on some parts LOL,
I am very proud of my son Sean he just graduated with a deg. in Computer Sceince, this took him a wopping 7 minutes and never used Mach3 before, now I have more good ideas. First I need a bigger desk, do you like my cut file?
Bladder water table
Sheetcam, Mach 3
Corel DrawX7
TurboCad 2015
211 Miller Mig
Harbor Ref. Dryer
Bladder water table
Sheetcam, Mach 3
Corel DrawX7
TurboCad 2015
211 Miller Mig
Harbor Ref. Dryer
Looks good Ron, I'd be interested to know more. I no longer run the CandCNC screen that you do but do still run Mach3 on my tables and that would be a real handy addition.
Murray
Murray
- rons
that's full scale on the tool path monitor
Bladder water table
Sheetcam, Mach 3
Corel DrawX7
TurboCad 2015
211 Miller Mig
Harbor Ref. Dryer
Bladder water table
Sheetcam, Mach 3
Corel DrawX7
TurboCad 2015
211 Miller Mig
Harbor Ref. Dryer
If only I had more room!! My Desk is full..
Still learning!
4x8 homebuilt w/Water table - Hypertherm Powermax 45 (Machine torch)
13" Metal Lathe
7x12 Meta lathe
1-1/2hp Milling machine
Hobart 190 Wire feed
Hobart EZ-Tig
Elcheapo powdercoating gun W/Autoclave oven converted for powdercoating.
13" Metal Lathe
7x12 Meta lathe
Hobart EZ-Tig
Hey Ron.. Looking good.
Do you have the setup recipe from your son, i need the same setup as you ..
Do the computer need 2 graphic cards?
Greetings Mikael
Greetings Mikael
I am interested in this as well.
- rrossetti
another option is to use the sheetcam plugin for mach 3 if you want a larger picture on the screen
