Muriatic Acid
Muriatic Acid
Am I over expecting? How is the metal supposed to look after the acid bath and dry? I've been using the acid for a short time now. Its kind of a love/hate relationship. What is the metal supposed to look like after you take it out of the acid?? I'm using hot rolled with P&O. For some reason I thought I would get a "silvery" color, but it is a gray. No shine! Is that normal??
BTW, I found my tub at WalMart. It was in the outside deck department. It holds 50 gallons and has a nice tight fitting hinged lid. It holds everything that I cut. I only have a 2x4.
Am I doing something wrong, or is this what I should get????
- tnbndr
Re: Muriatic Acid
That is what it should look like. To get the shiny steel you are expecting you will have to run over it with 120 grit on a grinder or belt sander.
You should not have to acid soak P&O as that is what pickling does, remove the mill finish from the hot rolled processing.
Re: Muriatic Acid
But it does help with the dross. Thank you!!!! Now I know. Thought I might be doing something wrong.
Re: Muriatic Acid
Maadman what are the dimension of the tub you bought, I have looked high and low and cannot find one I need. I cut the tattered flag about 32" long and have not found anything that I could use. I have tried to get a chemical tote that other guys use but the closest place that has them for sale is about 250 miles away. My next place is going to be a used gas tank from a wrecked car or truck and cut the top off, but don't know if that will be big enough.
- little blue choo
Re: Muriatic Acid
Hey acourtjester, I had the same problem. I was cutting things that wouldn't fit in my acid bath but found this on Amazon.
http://www.amazon.com/Dee-Zee-6537P-Pla ... e+tool+box
It is 40 inches over all but is 37 inch inside. It has a hinged lid and is very solid built. The best money I've spend. Hope this helps those hunting a good container for their acid.
Rick
Rick
Rick
Arclight 9600 4x8 table
Re: Muriatic Acid
Sorry for taking so long. Doing Sunday things. Will respond in about an hour.
Re: Muriatic Acid
Thanks little blue choo I was not looking in the right place I did a google check and the prices were all over the place and there was a bigger one too.
But after thinking this is a truck type tool box I did a different search and came up with this one and they have them locally I need to lay eyes on it to be sure.
http://www.homedepot.com/p/Husky-35-in- ... /205053257 $54.
More great info from Plasma spider
Re: Muriatic Acid
Just got back. The box I have is 19 in wide and 34 in long, inside dimensions . It came from Walmart and was $50. It is strong with a tight fitting hinged lid. Both your other options looked very good too. Good luck.
Re: Muriatic Acid
While we're talking about muriatic acid, what concentration are you guys using? I mixed a gallon of acid bought at the hardware store with 5 gallons of water. It seems to be a bit weak.
I bought a large heavy poly storage tote with a lid from Home Depot. So far, it's worked out pretty well. I wouldn't mind having something larger at some point.
- little blue choo
Re: Muriatic Acid
I looked at the ones at home depot but they were to narrow for me. I cut a lot of signs that are 24" x 24" or larger and the Husky's aren't that wide. The DEE ZEE was the only one I could find that would fit a 24" x 36".
Rick
Rick
Rick
- little blue choo
Re: Muriatic Acid
GSI I may be mixing mine to strong but I do 1 to 1. I purchase mine from a local chem. co. and give $30 for a 5 gallon can. If someone out there is using a different ratio let me know what it is and how it works. Never too old to learn something new.
Rick
Rick
Rick
Re: Muriatic Acid
Well I went to HD and found both the husky 50 gal and Dewalt 63 gal I bought the Dewalt and still was not wide enough inside.
and after getting it home I am not liking the foam seal I think the acid with break it down so I'm taking it back.
- Capstone
Re: Muriatic Acid
I went to Tractor Supply Co. and got a large water trough. I couldn't find the specific one I purchased, but it's similar to this one, but a lot deeper. Once filled, it can handle really large pieces. Since all of the signs are flat, 31 in. x 52 in. x 12 in, is a really good size to work with as far as getting the entire piece covered. Oh, and I just thought about the seal, the one I have has a copper drain plug and it held a full bath for a few months with no problem.
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
CNC Metal Design
JD Squared 4x8
Re: Muriatic Acid
Thanks tractor supply is about 1/4 mile for the Home Depot I went to so that will work.
- steel 35
Re: Muriatic Acid
I have a 110 gallon tank with maybe three inches of 2:1 in it. The copper bung is removed and a pvc bung? replacing it. It would make that gorgeous flag look tiny.
Real close to this if its not & no lids for it.
http://www.tractorsupply.com/tsc/produc ... nk-110-gal
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
Hyp 65 duramax's
EasyScriber
Re: Muriatic Acid
For my very large pieces, I went down to the hardware store and bought some of those huge, thick plastic contractor trash bags. Put the piece in it, add a few cups of acid from tank, seal it up and set it flat on the shop floor. After a couple of hours turn it over and let it sit again. Completely removes the mill scale and I just carefully pour the acid back in the tank when done!
PlasmaCam DHC2
Hyperthem PM65
Edwards 25T Ironworker
Hyperthem PM65
Re: Muriatic Acid
Well after playing tank shuffle with different size tanks I settled on the one Steel 35 recommended from tractor supply.
Ok steel where did you get the PVC bung???
- steel 35
Re: Muriatic Acid
I stand corrected; Its a (Bulk head fitting). ABS probably its Black, and a PVC Plug.
Not going to say what size because I would be wrong. First Local plumbing store I went to.
PPL HDG 4X8
Hyp 65 duramax's
EasyScriber
Hyp 65 duramax's
EasyScriber
Re: Muriatic Acid
Thanks that gives me a mission to go on
Re: Muriatic Acid
I'm pretty new to the site and still learning a lot from all the great posts. I ordered a 4 drum Haz Mat containment basin. It is only 7 inches deep but it is 51.5 square so large pieces can easily fit. The one I ordered is an Eagle 1638 4 drum basin. The best price I found was Wal Mart online at $146.00 with free shipping. Hope this helps some of you.
Mark
Tracker 4x8 Pro Table
Hypertherm Powermax 65
Corel X7
Corel X7
Re: Muriatic Acid
Laying pieces down hasn't worked out for me in acid. I searched high and low and found screen printing dip tanks. I have a small table but found a 24x24 dip tank 3.5" wide used on craigslist. So far it's been ideal, the top has a lip that allows pvc pipe to rest and hang parts in. I keep it out back and only use 1gal of acid in it, works great.
http://www.easiway.com/equipment/dip-tanks-accessories
