It is currently Sun May 27, 2018 11:21 pm
student version
Corel Draw Graphics Suite related questions and tips can be posted to this topic.
hacnwac
student version
Postby hacnwac » Mon Feb 29, 2016 8:54 pm
A couple of years ago I bought X6 from the plasma store here and its been great.My problem now is that I need to install it on a different 2nd laptop and I've lent it out and the disc is gone. I was just wondering if i got a student version to keep the cost down can I just use it and send the file to the full version of x6 and export dxf file from it. I have a tracker table and I usually export as a plotter file anyways but I don't know if the student version can even do that.
Thanks Mark
btburn
Re: student version
Postby btburn » Thu Mar 24, 2016 9:40 pm
My education edition of x7 does everything (my wife is a teacher). The only difference according to the lady that I spoke with at Corel said that on the education edition it says " not for commercial use" on the top of the program screen. On the old versions they used to limit the export types and not include fonts and extra stuff but now it just says that.
Dynatorch 4x4 SuperBee, Powermax 65, Quincy QT-54, Snap On MM250SL, Thermal Arc Arcmaster 185, Corel Draw X7 and a messy garage.
runninwild400
Re: student version
Postby runninwild400 » Mon Apr 18, 2016 6:03 am
I bought a student version a couple years ago to keep cost down and it wont save as a dxf
Metal-Magic
btburn
Re: student version
Postby btburn » Wed May 11, 2016 2:39 pm
runninwild400 wrote:I bought a student version a couple years ago to keep cost down and it wont save as a dxf
The X7 student version does DXF, SVG, and a ton of others that I don't use.
hacnwac
Re: student version
Postby hacnwac » Sat May 14, 2016 1:05 pm
Thanks for the info.
Mark
steel 35
Re: student version
Postby steel 35 » Mon Jan 09, 2017 11:08 pm
I just bought the Student Version X7 and Not able to Import or Export DXF. SVG it is till I learn otherwise. First thing's I tried.
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
Re: student version
Postby tnbndr » Tue Jan 10, 2017 6:08 am
Just guessing here as I don't have Corel but did you try "save as" and see if there is a pull down to select dxf?
PM45
Miller 211
RW 390E Slip Roll
steel 35
Re: student version
Postby steel 35 » Tue Jan 10, 2017 12:22 pm
I tried lots of thing's and was on the wire, because of what I read here. Figured I would try it because it was so affordable where as the full one is out of my budget. Just found this fine print on a Corel help site. Trying to clarify this post.
PPL HDG 4X8
Hyp 65 duramax's
Re: student version
Postby acourtjester » Tue Jan 10, 2017 5:05 pm
Well Poop I wish this was posted before I ordered my copy :o :(
Everlast PM 256 tig
RobinHillMachine
Re: student version
Postby RobinHillMachine » Tue Jan 10, 2017 6:51 pm
There's a difference between student version and student edition. You want a green box for Corel. The yellow/orange one will not allow DXFs.
Julie's the name, DXF is the game. http://robinhillmachine.com
steel 35
Re: student version
Postby steel 35 » Tue Jan 10, 2017 7:22 pm
CorelDRAW Graphics Suite X7 Academic
So this may be the one to search for, hope it's straight now.
Thanks; and sorry acourt, I am usually a little slow.
PPL HDG 4X8
Hyp 65 duramax's
runninwild400
Re: student version
Postby runninwild400 » Tue Jan 10, 2017 7:32 pm
I had the same issue, that's why I posted that it wouldn't do dxf's so others wouldn't waste their money like I did.
Metal-Magic
Re: student version
Postby acourtjester » Tue Jan 10, 2017 7:43 pm
On its way back to Amazon :(
Not your fault Steel 35
This is the post that I saw and ordered it.
Everlast PM 256 tig
Gamelord
Re: student version
Postby Gamelord » Tue Jan 10, 2017 8:16 pm
One thing you can do that may save you some money is to find a used full version of X3/X4 etc... You should be able to pick that up off of Fleabay for 30-50 bucks. Then, once purchased, install and you can then buy the Upgrade. Look for it to be on sale from Corel, you can find upgrades for usually under 200 bucks. This is a lot cheaper than purchasing the full version outright.
hacnwac
Re: student version
Postby hacnwac » Tue Jan 10, 2017 10:26 pm
I was wrong in my original post as it was x5 I had purchased from plasma store. I ended up doing what Gamelord mentioned above and got a good deal ($50 ) on x5. Gamelord is correct as well in the fact that corel has advertised upgrading to the newest version for as low as $174 CAD. I just haven't taken advantage of it yet.
Thanks Mark
sawdust1
Re: student version
Postby sawdust1 » Wed Jan 11, 2017 12:51 am
This may be completely irrelevant. I found that with the program I use I must "select all" or nothing happens when I try to export. Took me a long while to figure that one out!
cutting$burning
Re: student version
Postby cutting$burning » Mon Jan 16, 2017 11:24 am
This also may be irrelevant but I have x7 "Education Edition" not "Student" and everything seems to function properly. It does say "not for commercial use" as btburn mentions above. I do have some problems with DWG files but it's probably operator error not the software as I am still learning Corel and have a long way to go. Apparently there is a difference between the student and education versions, go figure. I was going to share the link from ebay where I purchased mine but I could not find it, again go figure. I hope this helps. Thanks D
