It is currently Mon Aug 20, 2018 3:32 am
Dynatorch continues cutting
Dynatorch hardware discussion forum
stevewrobins
Postby stevewrobins » Sat Mar 26, 2016 11:07 am
This may sound a little weird but i have a few files that when i cut them, it gets to a certain point and then just keeps cutting on that direction, it never makes the turn. It the same spot everytime. I downloaded the file, imported it into Inkscape to clean up, opened it in sheetcam and set it up and then opened in Dynatorchs software. At no point am i seeing this line that runs off to the side. I emailed Dyntorchs support but its Saturday before Easter so im not expecting any feedback today. Any ideas what is going on? I have also opened one of the files in Qcad and im still not seeing what is going on. Thanks in Advance guys.
Steve Robins
One 7 Refined Metals
Dynatorch 4x8
Hypertherm 65
Bigrhamr
Re: Dynatorch continues cutting
Postby Bigrhamr » Sat Mar 26, 2016 11:41 am
Can you post or send the DXF and the G code for one of them and indicate the problem spot?
What happens if you rotate the drawing 90 degrees and do a test run?
Any chance the drawing has a hidden layer?
stevewrobins
Postby stevewrobins » Sat Mar 26, 2016 1:34 pm
I have attached a pic and the DXF. Its a file i downloaded from here but i dont see anything out of the ordinary. I turned it 90 degrees and it did thesame thing. Once it come off the R in the middle it continues to keep coming down. Dont put yourself out of anything looking at this but i do appreciate it.
Steve Robins
Dynatorch 4x8
Hypertherm 65
Bigrhamr
Postby Bigrhamr » Sat Mar 26, 2016 2:06 pm
I didn't see anything for sure that would cause that but it did have lots of extra nodes including a couple that weren't attached to anything. See if this works any different.
stevewrobins
Postby stevewrobins » Sat Mar 26, 2016 4:11 pm
Thank you for the help, that worked. I had another file that was doing the same thing and where it was taking off, i just deleted that section and that corrected the problem. There is something a little flaky going on right there. Atleast now, i know where to start if it happens again. I do appreciate your help.
Steve Robins
Dynatorch 4x8
Hypertherm 65
TMC
Postby TMC » Mon Mar 28, 2016 8:22 pm
many times with my Dynatorch if it just continues on in a straight line there is a problem with one node. If you go back to your design software and zoom in on that node I always find that the node line doesn't continue properly and has a very tight loop in it around the node. Take the node handles and manipulate the loop out and it should fix it. If you didn't know, you can open your Dynatorch software in demo mode, import the file and do a dry test cut without having to turn power on to your table. I do this all the time before I ever cut a file to make sure there isn't anything funny with it.
Talbot Metal Crafting
DynaTorch 4x4 SuperB
Hypertherm PMX 85
Corel 7X
Solid Edge
SheetCam
Easton, Maryland
stevewrobins
Postby stevewrobins » Wed Mar 30, 2016 8:09 am
Thanks for the advice Talbot, I will definitely do a test run prior to cutting from now on when using a new file.
Steve Robins
Dynatorch 4x8
Hypertherm 65
Return to “Dynatorch”
