It is currently Tue Aug 21, 2018 11:44 pm
Draftsman cut shop /Dynatorch questions
Dynatorch hardware discussion forum
Eelsteel
Postby Eelsteel » Fri Oct 02, 2015 10:09 pm
Hello,
This is all new to me. I've been handcutting my metal pieces for 13 years and finally decided to get a cnc plasma system.
I have a 4'x8' Dynatorch super B with a hypertherm 65 and arbor image draftsman cut shop software.
My question is : I'm scanning my origional drawing, vectorizing the image, scaling it to size and saving as a dxf.
Then I'm opening it in the dynatorch software and it states that it is to large and goes beyond the table limits and it doesn't show up at all on the screen.
Ive been reading the arbor image manual but I can't find anything addressing this problem. Any help at all would be greatly appreciated.
TMC
Re: Draftsman cut shop /Dynatorch questions
Postby TMC » Sat Oct 03, 2015 2:58 pm
Are you running through sheetcam to turn it into a cut file before you import it into Dynatorch? You scale it using Sheetcam as well
Talbot Metal Crafting
DynaTorch 4x4 SuperB
Hypertherm PMX 85
Corel 7X
Solid Edge
SheetCam
Easton, Maryland
illusivedf
Postby illusivedf » Sun Oct 04, 2015 12:01 pm
Did you zero out the origin?
Owner at Illusive Design & Fabrications
http://www.illusivefabrications.com
Air Ride Suspension Parts
Metal Fabrication
Dynatorch 4x8 with Hypertherm 1250
Vinyl Decals & Signs
Powder Coating
cstroke
Postby cstroke » Sat Oct 31, 2015 9:24 am
EDIT tab:
Select all
Edit Tab:
Uncleave selected poly lines
then optimize.
This will reduce the number of points.
Show all points first if you want to compare how many you reduced.
Hope this helps.
Return to “Dynatorch”
