Any one using a 6'x12' dynatorch?
Curious as to the cut quality of the larger machines.
I'm very seriously thinking of selling my 1250 powered single side drive 5'x10' machine to a 6'x12'.
Thinking of a 6'x12' with a scribe and new powermax 85 and possibly the pipe cutter.
Any thoughts?
Chris
5'x10' or 6'x12'?
- cstroke
5'x10' or 6'x12'?
6’x12’ Dynatorch powermax 85
12’ Wysong brake
5’x 5/16’ wysong rolls
3.8’x10’ shear
65 Ton ironworker
Boss laser 3655 150 watt CO2.
SFX 100watt Mopa
Quicncy 7.5hp
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
Re: 5'x10' or 6'x12'?
I run a 5x10 XLR8 table. No complaints as far as table goes. Any cut quality issues has been directly related to the plasma. Except I had the bolts on the slave motor bracket come loose once, took a little bit to figure out where the problem was.
- cstroke
Well it's official..
I've got a 6'x12' xls on order
tube cutter
engraver
new powermax 85 to top it all off.
I also ordered a spare set of the torch mounts to put a drill on to jewel(engine turn) sheets of aluminum or stainless.
Now for the fun part, paying for it all..
tube cutter
engraver
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
Pardon my ignorance but why do you need a 6 x 12 table? Are 6 x 12 sheets of steel readily available? I realize they have tables up to 40' long (and probably larger) in factories and large fab shops but have never seen any steel larger than 5 x 10. What do use the table for? Thank you for the info as I have always kinda wondered what guys use these larger tables for.
- cstroke
Most of the time I dont need that big of a table. Most of the time I can get by with the 5'x10' table.
I have one job that I do that if I use a 6' wide sheet it minimizes the waste that I have.
I was still on the fence with jumping up in size but I can still get the artsy performance with this size so I went for it.
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
Thanks for the info
