It is currently Mon Jun 18, 2018 3:45 am
Saving a dxf from plasma spider
jspake
Postby jspake » Wed Jun 13, 2018 8:04 am
Every time I try to open a dxf it opens in autocad inventor... I haven’t had that much experience with auto cad because I just downloaded it. Is there a way to just save a file to import into my plasmacam software? It used to pop up and say it can’t open and a copy of it would be in my downloads.
Thanks!!
rdj357
Re: Saving a dxf from plasma spider
Postby rdj357 » Wed Jun 13, 2018 8:16 am
right click on it and choose save link as.
Robert Johnson
FourNinety Creations
PlasmaCam 5x10
Snap-n-Cut Mount
PM 65 w/ Mini Machine Torch
Router Attachment/DW611
VCarvePro & Photo VCarve
SpectraCoat Powder Coat System
7'x7'x10' DIY Powder Coat Oven
nevetskrats
Postby nevetskrats » Wed Jun 13, 2018 6:19 pm
Open plasmacam first then go to file, import and see if that works
beefy
Postby beefy » Wed Jun 13, 2018 6:36 pm
Click on the link and the file downloads to your "Downloads" folder.
Otherwise right click on the link and choose "Save Link As", then you can select the folder where you want to file to download to.
Open PC, and under the file menu, choose "Import..."
In the popup box, drop down the file type box and select "Autocad DXF files (*.dxf)"
Just tried in PC v3.1 and works perfect.
8 x 5 water table
Powermax 1250 with Duramax torch
UCCNC controller, UC400-ETH & UC300-ETH motion controllers.
Geomagic Design 3D solid modelling
Coreldraw X5
