Special request for my father. I need help converting this to a .dxf.
Thank you,
Linda
Olds 4-4-2 Car Conversion
Re: Need help converting
Here's my shot at it. Check for burn outs if cutting small, may have to eliminate some detail.
WOW!! That is perfect!! Thank you so much!! I will post a picture when I get it cut.
Car Conversion
Nice job sbest1! What car is that anyway?
- Francisco
Re: Car Conversion
'70 Olds 4-4-2?
Boy, I'm old...
Boy, I'm old...
- Larry83301
Re: Car Conversion
Francisco wrote:'70 Olds 4-4-2?
Boy, I'm old...
I'm old TOO! Two years out of my apprenticeship when that came out.
That could be a '71 (grill height to light height), but it's definitely An Olds 4-4-2
Re: Car Conversion
Thanks Francisco, not at all what I though it was.Francisco wrote:'70 Olds 4-4-2?
Boy, I'm old...
- Francisco
Re: Olds 4-4-2 Car Conversion
Larry is right; it's a '71 or '72 - The 1970 model's grill openings were at the same height as the top of the headlight assemblies. GM probably judged it looked too much like its Chevelle sibling.
- david jordan
Thank you.
PlasmaCam DHC 2 4 X 4 table
Powermax 65
400amp mig welder with dc tig
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Sothbend, 5C collets
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Powermax 65
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Hendy lathe
Everlast Tig200 Amp
PL1220
