I made this dxf file but shows it has 63 intersections. Most of them are along the curved portion of the file. Can someone please help with this?
Help with DXF clean up
- primaldesigns
- 4.5 Star Member
Re: Help with DXF clean up
That dxf file was seriously corrupted, and amongst other oddities, had duplicate lines on the top curve.
Anyway, after some mucking with nodes and finding/deleting the duplicate lines, it was still well stuffed up, but I managed to get a "fill" object from the file (basically creates a new object from the bounds of another object).
See if this is any good:
Keith.
Keith.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
LinuxCNC
Coreldraw 2019
- rdj357
Lots of double lines. I got it cleaned up by deleting the overlaps and kept the same scale you had. Here's a clean 61 node file.
Robert Johnson
Learn Plasmacam Workshops
Learn Plasmacam on Facebook
Learn Plasmacam on YouTube
- primaldesigns
Thank you Robert & Keith.
I really appreciate your help and hard work.
Looks like both files will work!
Primal
Primal
