A kid from high school needs help cutting a piece since we have a bigger table than the school does. The problem is he drew it in plasma cam and we can't seem to figure out the converting part. Anyone out there willing to help us out?
3D Dinosaur - Pcm to Dxf Conversion
- rdj357
Re: pcm to dxf
Here ya go. Tell the lad next time to only convert to cut paths just before cutting and any time they want to share or do something on a different table they need to save the closed/open paths by themselves. If they have advanced design software for their plasmacam they can choose to export it to a DXF for your machine.
I cleaned up these quite a bit. They were all open cut paths with lead ins (which your CAM software probably wouldn't have liked!) and there were several intersections and stray lines. I did NOT check the slots so I have no idea if it will fit together or not but worth some testing or cutting!
Good luck!
Good luck!
Robert Johnson
Learn Plasmacam Workshops
Learn Plasmacam on Facebook
Learn Plasmacam on YouTube
- steel 35
Re: pcm to dxf
The slots are messed up indeed. Unless his target is around 1/2" plate.
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
Hyp 65 duramax's
EasyScriber
Re: pcm to dxf
Thank you rjd357! I will relay the message, I know their plasma cam is an older unit so that may be part of the problem with exporting. I put your file on my Vicon and everything looks good, but I do see his slots aren't consistent at all so I will talk to him about what he expects for fitting together.
Thanks again!
Thanks again!
Re: 3D Dinosaur - Pcm to Dxf Conversion
Thanks for the share, love these 3D designs!
how much would one charge for this?
- david jordan
Nice job, thank you.
PlasmaCam DHC 2 4 X 4 table
Powermax 65
400amp mig welder with dc tig
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Sothbend, 5C collets
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Powermax 65
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Hendy lathe
Everlast Tig200 Amp
PL1220
