It is currently Sat Feb 17, 2018 6:26 pm
newby needing help
pcilse33
newby needing help
Postby pcilse33 » Fri Nov 03, 2017 8:53 pm
Is there any way to convert dxf files to something Adobe Illustrator can open?
Re: newby needing help
Postby Larry83301 » Sun Nov 05, 2017 10:44 am
Illustrator will not open AutoCAD files saved in a version later than AutoCAD 2007. AutoCAD files include both DXF and DWG formats. You can import AutoCAD files from version 2.5 through version 2007.
So just open the DXF file you want to work with in a CAD program and save it as an old ACAD file.
ironhorse
Postby ironhorse » Wed Jan 10, 2018 6:21 pm
Thank you for the info on that as it will work for me as well.
MemFor
Postby MemFor » Thu Jan 11, 2018 5:01 pm
Use an online converter to make it a PDF then it will open. You have to remove a few layers of clipping masks in most cases.
