I need the top and bottom arc traced if possible
anybody want to take a stab at tracing?
- kchoghead
Re: anybody want to take a stab at tracing?
Another poster had suggested laying paper over thing to trace then use a scanner to load it into your computer then use Inkscape trace to convert to a DXF or SVG file. If you do that you can scale it to what ever size you want.
- kchoghead
this is a pic that a friend sent me to see if i could cut it out... I use torchmate cad, but the scanning feature of this software does not like this.just a bunch of squiggly lines
- rdj357
I'm trying to understand what you're after. Just the top and bottom arches with text or the whole thing?
Robert Johnson
Learn Plasmacam Workshops
Learn Plasmacam on Facebook
Learn Plasmacam on YouTube
It is a start.
- kchoghead
Thanks a million noclinkers.. i was looking for the top and bottom with text... You nailed it...I wish i could trace like you do
Just practice. I am using TMCad like you are.
- kchoghead
I will take that advice, knowing that you use tm cad ad have those results. most things trace pretty good but when I try to trace patches and such the lines are all over the place.
That came out wrong. I meant that I just practice to get to where I can use the program to do almost anything I need to.
I wasn't advising you to do anything, that is up to you.
