Pirate Face - School Sign
Hey all, I've been tasked with doing a welcome sign for a local elementary. The principal wanted their logo (probably a multi layer as she wants multi colored) I'm having trouble wrapping my head around how to go about this. Any advice you can offer would be very much appreciated.
She wants a little blue and yellow (the school's colors) and the rest to be black. Looking for a 36" Diameter circle that says "Welcome To Gosnell Elementary School" It will be Staked into the ground with the bottom of the circle 24" above ground.
Re: Donation For Local School Seeking Advice.
I can give you a one layer cut ready file but not for free. Let me know if you're interested.
PlasmaCam DHC2
Hypertherm Powermax 65
Millermatic 211 MIG Welder
with the one layer file how would you suggest I go about adding the colors? cut a backing piece and paint it?
Can you give a ballpark estimate on what you would charge?
here is the sign broken into color parts less the yellow ring on the outside, mount them on a white background.
You can paint the black parts and the face parts flesh and the letter another color. Assemble in a layered style
attached both DXF and SVG done with inkscape.
- RobinHillMachine
Cut it as a two layer with 4 sections. Back plate is solid but you'll have to add your hanging holes to it. Then the white circle with the name. It's cut out to let the black from the back plate show through. Then there are two face pieces and two scarf pieces. Secure those to the black plate. I suggest using a spacer between the black and white circles just to give it a bit more dimension.
Post a picture when you get it cut and painted. I want to see this one.
If the buccaneer's scarf was orange, it would be my school logo.
~Julie
~Julie
Wow! Thank you so much acourtjecter and RobinHillMachine!!! Both of you have gone above and beyond, I never expected or asked for this to be done free of charge. I would have happily paid icmplasma85 or either one of you for your services.
The community on this forum is fantastic and seems to get better with every new contributing member! I do my best to give back to the community in any way I can and hopefully one day I can return all the favors I've racked up lol
I will definitely be posting pictures of the finished product. Thanks again for the advice and conversion!!
- RobinHillMachine
I typically would have scrolled past this one but that's my mascot. I had to do it. Go bucs!
Well, here is the sign painted and assembled. I will get another pic up when it is installed on site. Thanks again!
- RobinHillMachine
That came out incredible! Thank you for sharing the picture. I hope everyone at the school loves it when you deliver.
Always nice to a project from start to finish, it helps to give other an option to see how a drawing can be modified to enhance the final product.
Re: Pirate Face - School Sign
Both conversions are awesome and thanks for showing the finished product. Turned out great! I can use the Pirate portion too which is awesome!
I'm going to assume that admin relocated this post from the conversion help wanted section. Thanks admin!
- Specialkfab
How did you attach the layers?
DHC2 PlasmaCam 4X4
Pipe Attachment
HyperTherm 45XP
Pipe Attachment
HyperTherm 45XP
- Capstone
Looks Great. Awesome collaboration with the community.
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
CNC Metal Design
JD Squared 4x8
I used 8-32 screws and nuts. I welded the nuts to the back side of the pieces and drilled holes through the backing plate. Everything is fastened from the back side to hide the all the fasteners.Specialkfab wrote:How did you attach the layers?
Sorry all, I forgot to add the picture of it installed. I was planning on getting a better picture since I wasn't happy with the lighting at the time this photo was taken but anyway here it is.
Very Nice!!! That's what it is all about !!
1250 hypertherm
4 X 8 Precision Plasma
CandCnC electronics
CandCnC electronics
- RobinHillMachine
I love how you spaced the welcome to let the shadows go thru like that. It came out fantastic!
Thank you, The welcome and the white parts are spaced 3/4" off the back piece. All the pirate head parts are spaced roughly 3/16" off the back (the thickness of the nuts used)
