dxf fonts
Re: dxf fonts
An entire "font"? There is no such thing as DXF font files. Each letter would have to be a separate DXF file. You could not bring them in to a drawing and type in the letters or have it place a line of text with proper letter to letter (kerning) spacing. You could not move the whole line or resize it using the typical size metrics for a Font: Point.
You need to use a drawing program that will let you load normal Windows or Adobe fonts . A "Font" is actually a collection of vector shapes that has embedded info about the kerning, font family , and lets you operate on a whole line . The export DXF has NO provision for Font info so they have to be converted to just a group of vector objects.
You can get script fonts but If your gaol is to have something like a monogram with very cursive type letters then they are typically individual letters . While there are some in DXF format letters , there are lots more in more standard vector formats like AI . EPS or CDR.
If your drawing program won't use Windows Fonts or import other vector formats besides DXF then your ability to do decorative cutting will be severely hampered.
- RobinHillMachine
Re: dxf fonts
Download them for free on dafont.com and convert to curves once you type out your text. They have a big stencil section if you need reverse cut ones.
Re: dxf fonts
I use a program many of you are probably already familiar with called DeskEngrave. It's free and easy to use, it uses fonts already installed on your computer and exports them in dxf or gcode. I do all my drawing in CAD so not sure how or if this will work with the folks primarily using SVGs. Additional fonts are easily downloaded and installed from dafont.com . Thais program makes it really easy for me to put words on a radius and quickly switch between different fonts with a preview window so I can pick which font looks better for a project.
http://www.deskam.com/deskengrave.html
There is also a program called stickfont which I've used on rare occasion to make open line fonts.
