It is currently Thu Jul 19, 2018 11:42 am
Won't fire up
Arclight Hardware discussion forum.
seajinx
Won't fire up
Postby seajinx » Fri Aug 21, 2015 7:33 pm
Ok, Connected all the X,Y,Z and A wires to my ArcLight 12000. Brought my file in to Mach 3 Hit run and Zilch, nothing, Nada. The gantry moved to the start point, touched the plate, came up and stopped there. Not even a hint of spark from the HT 85. I'm cutting 12 gauge steel, tip is 85 amp and the HT 85 is set to 85 amp output. I'm assuming you set the Amps on the Torch acording to the amperage your tip is set for or is my thinking wrong. And can someone tell me where the PMW network wire connects to?
seajinx
Re: Won't fire up
Postby seajinx » Fri Aug 21, 2015 9:35 pm
Cancel the PMW connection. Found it went to the HT 85 sensor. Is the voltage to torch suppose to be a constant reading or is it erratic until it makes an arc? This is a big learning curve for me and in need of help. Thank you.
seajinx
Re: Won't fire up
Postby seajinx » Sat Aug 22, 2015 11:47 am
After a thorough brain racking and frustrating moments. I've located the culprit of why it wouldn't fire up. Apparently my wiring in the plug o he plasma cutter didn't have proper contact. System is up and running, but ran into a snag with the THC tip Volts outside fault range. found my answer in the PS search. Was a simple jack up the Air pressure and problem solved. Thanks PS for a great web site.
WyoGreen
Re: Won't fire up
Postby WyoGreen » Sat Aug 22, 2015 5:52 pm
I'm glad we were able to help! :lol:
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
CNC Router table
drossmaker
Re: Won't fire up
Postby drossmaker » Mon Aug 24, 2015 5:17 pm
seajunx,
We are glad to hear your table is up and running. If you ever have issue or questions about your table give us a call for a faster response: 866-222-2154. We check PlasmaSpider M-W-F.
-drossmaker
drossmaker
Re: Won't fire up
Postby drossmaker » Tue Nov 03, 2015 2:54 pm
seajinx,
glad we were able to get you back up and running.
-drossmaker
Return to “Arclight Dynamics”
