It is currently Thu Feb 22, 2018 7:39 am
Having issues cutting Stainless... Jim/ Ross Help!
Trucut CNC Hardware discussion forum
SSLLC
Postby SSLLC » Mon Jun 16, 2014 7:27 pm
So I took it upon myself to try cutting some 20GA stainless to go on a boat trailer side rails with boats name on it. My issue is the pilot arc lights then goes out. I have moved and cleaned my ground twice and took tip off and inspected. Appears fine. I am using 45amp fine cut tip unshielded. Everything set per manual and about 30% under IPM from owners manual. I have never cut stainless before on a plasma table. With that being said I could be making a simple mistake that Im not aware of. Other info - powermax 65 @ 40 amps, 45 amp unshielded fine cut tip, pierce .08 cut .02 delay .1 and feed rate 160. @Ross and Cindy - This machine is awesome very pleased with it!
cindy carlisle
Re: Having issues cutting Stainless... Jim/ Ross Help!
Postby cindy carlisle » Tue Jun 17, 2014 11:44 am
I think Ross covered this via email , please let us know how it works for you :)
Thank you, you guys "Rock"
I am going to share your first job with your PM65 and our TruCut CNC
Cindy
http://www.trucutcnc.com
615-290-6260
Return to “Trucut CNC”
