It is currently Sun Jul 15, 2018 11:08 pm
Cursive Font question
DXF Art Sharing Forum is for sharing dxf, plt, or any other vector file for plasma cutting. Browse what others have posted or post some DXF art files of your own.
KingoWelds
Postby KingoWelds » Wed Apr 25, 2018 10:30 am
Just wondering if anybody has found a cursive type font that doesnt require a ton of work to edit lines or doesn't break into 10000+ lines when exploded
thanks.
szextreme
Re: Cursive Font question
Postby szextreme » Tue May 08, 2018 3:40 pm
Not specifically cursive but check out Autumn in November pretty popular font and easy to work with
-Bulltear 5x12
-PM 85
-Miller Dynasty 400
-5000 Sq feet of toys......I mean Machinary!
Postby tcaudle » Thu May 10, 2018 4:34 pm
I guess it would depend on if the export process can preserve all of the curves (or better yet true Bezier Curves) Real Fonts (like Brushscript) are smooth curves . Its a broad font. Any script font will need to be joined so there are no over lapping lines. In CorelDraw you do that by "welding" (joining ) letters together to make a word or line of test, In Inkscape the ungroup then select multiple letters and perform a UNION/ There are no fonts that just flow non stop like hand writing The welding and artwork needs to be done in the Drawing program and the export to CAM should be joined objects .
ScriptFont.svg
ScriptFont-union.svg
Users browsing this forum: johno down under and 16 guests
