It is currently Sat Mar 17, 2018 6:26 pm
Cutting larger odd shaped items.
Share tips and tricks you know of in this forum. Plasma cutting, material handling, metal finishing, marketing, or anything that you feel is helpful.
Postby marcnaz » Thu Feb 08, 2018 12:52 pm
I have a large Nema electrical box (24x24x8) that I'd like to cut some square and round component mounting holes in the end/side (for connectors switches etc). I can remove my slats and water table and prop it up to the right height between the tables cross braces. Has anyone done this or cut odd shaped or items too large to sit on your slats to be cut? Since I won't have the water table, maybe a pan of water below, inside the box where I'm cutting, or a welding blanket? It won't fit on the mill either, so figure the plasma table would be better. Any tips or ideas would be welcome. I know they make punches for such things, but I don't have any and this is a one time thing.
Re: Cutting larger odd shaped items.
Postby tirediron » Thu Feb 08, 2018 5:10 pm
I've cut a piece of pipe that the diameter was so that I could not use my torch. I removed a couple of slats and this gave me the clearance that I needed. I then used the slats as a support to clamp the pipe in place. Don't know if this helps you are not - but I guess you can give it a try.
Postby Scratch » Thu Feb 08, 2018 5:13 pm
I had a large electrical box that I needed to cut some holes in. It was about 14" deep, 4' tall and 3' wide. I removed my slats and laid it down in the table. worked great.
Return to “Tech Tips”
