It is currently Wed Mar 21, 2018 10:28 pm
hypertherm powermax 45 HELP!!!!
Share tips and tricks you know of in this forum. Plasma cutting, material handling, metal finishing, marketing, or anything that you feel is helpful.
Postby Amyfreestone » Fri Dec 16, 2016 3:21 am
my powermax 45 will not arc at all. This morning it did the pssst sound and the tip light came on. I changed the components and cleaned everything. I switched from 45 to 30 amp components and adjusted the cut speed and height. It continues to make that psst noise and then the tip light comes on. I have been fighting it all day. cant think of what could have happened. Anyone experienced this before? Any help would be sooo appreciated.
Re: hypertherm powermax 45 HELP!!!!
Postby sphurley » Fri Dec 16, 2016 8:34 am
I think this should get moved to the Plasma Cutter forum/ Hypertherm.
Platform CNC Plasma table
CandCNC Ethercut IV DTHC
Hypertherm 85/CPC/RS485
Miller 350P
Miller Dynasty 280DX
Postby Sharp » Mon Apr 03, 2017 6:43 pm
you have it grounded? how many amps is it set too? too low and it will just check for air pressure and not fire
Return to “Tech Tips”
