It is currently Mon Sep 24, 2018 9:48 pm
Jog Speed
cfmetalworks
Jog Speed
Postby cfmetalworks » Sun Aug 12, 2018 10:48 am
Does anyone know how to adjust the speed of your torch while its moving between cuts?
I am currently using command CNC and Sheetcam. I didn't know where I would find the settings or if I could even adjust it.
Thank you!
Re: Jog Speed
Postby acourtjester » Sun Aug 12, 2018 11:03 am
YOu may get a quicker reply ifyou post it here
viewforum.php?f=115
Everlast PM 256 tig
Rodw
Re: Jog Speed
Postby Rodw » Sun Aug 12, 2018 11:49 pm
I don't know if CommandCNC has a configurator to set up Linuxcnc .ini file options but Jog speed is controlled in LinuxCNC in the .INI file in the [DISPLAY] section by the DEFAULT_LINEAR_VELOCITY setting. Note its in units per SECOND, not
DEFAULT_LINEAR_VELOCITY = .25 - The default velocity for linear jogs, in , machine units per second.
See http://linuxcnc.org/docs/html/config/in ... ay_section
Rodw
Re: Jog Speed
Postby Rodw » Sun Aug 12, 2018 11:51 pm
I don't know if CommandCNC has a configurator to set up Linuxcnc .ini file options but Jog speed is controlled in LinuxCNC in the .INI file in the [DISPLAY] section by the DEFAULT_LINEAR_VELOCITY setting. Note its in units per SECOND, not per minute.
Rodw
Re: Jog Speed
Postby Rodw » Sun Aug 12, 2018 11:54 pm
Also for a given axis or joint, there is a setting called MAX_VELOCITY which is the maximum speed your machine can run at. Its used for rapids.
Re: Jog Speed
Postby tcaudle » Tue Aug 14, 2018 8:49 pm
DO NOT root around in the ini files .
The Configurator is a GUI configuration tool for the whole system
Set the max velocity (rapid speeds ) of each axis here:
LOWER max rate on the fly here :
Return to “Tech Tips”
