What people are Charging an hour to Cut??
I bidding on one of my first bigger jobs the guy is supplying the metal. I just have to cut it out. Wondering if you charge per part or just do hourly?? The first set is 500 parts about 4''x5''x14G per part.. Any feed back would be Great Thanks..
- twicecustom
Re: What people are Charging an hour to Cut??
Jack of all trades, Master of none.
Benjiman
Benjiman
- pertneer
If you are looking to find what you need to charge per hour see this download. It is an exe download but it is all MTI systems offers for a download. I have been looking at there Costing software and discovered this little gem. It is free to download.
As far as what i charge I use the xlsx file I downloaded from this site( I believe, but I cannot seam to find the link). It is called "CNC Plasma Price Work Sheet.xls". I does a fairly decent job if you have all current data on steel prices.
Good luck
Good luck
I don't charge time for cutting. Square area of material used (if piece is a circle they buy the square size it took to cut it), cost per pierce, cost per inch to cut. Those costs depend on thickness of material. extra charges if its a heavy sheet to manuever around the shop (3/16" or more) or I have to index the sheet for big pieces. I charge for time for complicated design(not simple shapes), fabrication, welding, painting, etc.
this is the one I use also.( if they supply the mat just leave that part blank. )twicecustom wrote:http://www.plasmaspider.com/viewtopic.p ... eet#p27780
This has come in very handy for us.
great spreadsheet
I just ended up doing an hourly rate of 80.00 dollars. I firgured I could run 4 parts a min so I took 80/60=1.33/4=.3325
I came up with .33 a part plus .05 per pierce
Total per part .38 cents for a part that was about 3''x5x14g
I will have orders of 400 and 500 parts
Feed back on if this price is to high are low would be great thanks
If I cut a 3" x 5" rectangle out of 14ga, just a straight rectangle with nothing else cut in it it would be $2.80 for 1 or $2.00 each for 20 or more.GPWELDING wrote:I just ended up doing an hourly rate of 80.00 dollars. I firgured I could run 4 parts a min so I took 80/60=1.33/4=.3325
Ya after looking around more I was forsure a little to cheap. I figured out a work sheet that works alittle better and got me closer to the 2.00 a part...
Wondering what everyone is charging per cut inch and per pierce???
I have seen on this form some people charging
$ .33 per cut inch.
+ $ .15 per pierce point. Factors in consumable replacement cost.
+ $ 1.67 per minute of cutting based on $100.00 per hour for machine.
+ Material cost.
+ CAD, scanning, @ $55.00 per hour.
Seems alittle High but Would be helpful to know so I can get my foot in the door with some work..
$ .33 per cut inch.
+ Material cost.
