Grinding Station
Grinding Station
I've been thinking about this thing for a while now. Yesterday I brought it from CAD to life. Formed it up out of 11Gauge. Need to build a better dust tray for it as I can't form the exact piece I need on my press brake with the tooling I have. My solution to that is I will build a 16ga tray on my mag brake. Other than that, went pretty well.
5x10 LDR
Re: Grinding Station
Very nice.
Looks good! Are you going to put a fan on it to help control the dust? What about sides or curtains? I have a similar setup originally buit as a downdraft for manual plasma cutting, but it needs something to control the spark spray. I also put an old vise on it to help hold smaller parts.
This looks great! Does it have a tray for the bottom to collect the dust?
How is this working? Really need to build a grinding station. Tired of the dust all over the shop. Needs to happen in the next couple of weeks.
Home Built 4x4 CNC Plasma Table
Ethernet Smoothstepper
C25 BOB
MiniTHC
Hypertherm Powermax 45XP
Software: Mach3 and Sheetcam, Solidworks 2019 for serious design work and Inkscape for signs
C25 BOB
MiniTHC
Here is a commercial solution if you want an idea regarding vent rates and also the flaps / wings on the side are on hinges so that you can put long material into the grinding or welding zone.
https://www.nederman.com/en/products/ca ... 73/p-89020
It actually works pretty good. I don't really see a need for a fan on it but I'm also not sanding super dusty things like wood.. Just basically clean up from off the table.
5x10 LDR
