It is currently Wed Apr 25, 2018 2:36 pm
Wall hanging plasma parts?
This forum is for plasma cutting related tools and accessories. Discuss products and tools that have worked or not worked for you.
davek0974
Postby davek0974 » Mon Nov 07, 2016 3:21 am
Whats everyone using to hang wall art and projects ?
Was thinking something like these with maybe a tack-weld in the hole?
Capstone
Re: Wall hanging plasma parts?
Postby Capstone » Mon Nov 07, 2016 7:00 am
I use those, but with rivets.
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
motoguy
Postby motoguy » Mon Nov 07, 2016 9:39 am
I used to cut my own hangers, bend, and weld. I've since started using D rings similar to your photo. I use the larger version, with 2 holes. I weld them at the holes.
blackandtan
Postby blackandtan » Mon Nov 07, 2016 9:02 pm
I use the small ones like that and just tack them on I was just tacking the hole but I had one not hold so I got paranoid and started adding a tack on the side of them.
little blue choo
Postby little blue choo » Mon Nov 07, 2016 10:11 pm
I use saw blade toothed hanger like come on picture frames. They give me a little adjustability that the D ring doesn't and
I can get them for less than .01 each.
Rick
Rick
Arclight 9600 4x8 table
motoguy
Postby motoguy » Mon Nov 07, 2016 11:14 pm
little blue choo wrote:I use saw blade toothed hanger like come on picture frames. They give me a little adjustability that the D ring doesn't and
Rick
Which ones do you use? I used a few of those, but they were so thin it was a PITA to weld. Also, at the time I was using HR and welding hangers prior to dipping in acid. The sawtooths were high-zinc, and the acid ate them off. That's why I started cutting my own hangers (sawtooth included). Now that I use P&O, the acid bath isn't an issue. However, the bulk D-rings are still easier/cheaper than cutting hundreds of my own hangers, and I feel the customers like them better as well. BTW, I did acid test the D rings. The ones from Walmart dissolved, but the bulk 100 pack from amazon did fine.
If I could find a thicker/easier to weld, non-zinc sawtooth, I would definitely use them for some pieces.
little blue choo
Postby little blue choo » Tue Nov 08, 2016 12:12 am
Rick
I weld them after the acid bath. USUALLY today I forgot and polished 3 pieces before I noticed. I just welded them on and grabbed the grinder again. Just had to touch up where the metal discolored. They are thin but I just turn the welder down and go to it with 2 short burst per side.
Rick
Rick
davek0974
Postby davek0974 » Tue Nov 08, 2016 2:16 am
I've ordered some D-Rings and also some little plates with holes in, see what they work like.
The saw-tooth ones would be best but the parts are just letters so the area i have to fit them is quite narrow - most of the tooth hangers seem to be 40mm wide or more, also as said very thin.
Will see how it works out.
gamble
Postby gamble » Tue Nov 08, 2016 10:45 am
I buy small sawtooth ones from the hardware store. It's about $2-$2.50 for 6 small ones. They are galvanized.
I have a little HF spot welder to get them on
Torchmate 2x2
Powermax 45 - machine torch
Flashcut CNC Controls & Height control
davek0974
Postby davek0974 » Tue Nov 08, 2016 10:51 am
spot welder could be good, i only have MIG here.
gamble
Postby gamble » Tue Nov 08, 2016 11:12 am
Mig works too. And doesn't leave a dimple on the front side
Torchmate 2x2
davek0974
Postby davek0974 » Tue Nov 08, 2016 12:13 pm
great, should be here soon, will do some tests
davek0974
Postby davek0974 » Thu Nov 10, 2016 2:08 pm
D-Rings look ok, bugger to weld on but I think I have it now.
You can't weld through the hole - the metal vaporises before the pool gets a bite into the main part so i found it best to start a pool off to each side and then just flash onto the tab, feels pretty secure.
motoguy
Postby motoguy » Thu Nov 10, 2016 3:28 pm
davek0974 wrote:D-Rings look ok, bugger to weld on but I think I have it now.
I found just the opposite. I start in the middle of the hole, and just hold the gun in place. I let the hole "fill up" with molten wire, until it just kind of melds with the hanger. If I try to work the gun in circles inside the hole, it just blows away the D-ring material. In other words, letting the molten metal rise to the hanger tab works great, but trying to put the arc near the hanger tab is pointless.
That works for the larger, 2-hole style D ring tabs I'm using. I also have some very small single ring tabs, but I haven't found away to keep from blowing through them yet. The strap material on those is even thinner than the dual hole version.
davek0974
Postby davek0974 » Thu Nov 10, 2016 3:34 pm
Ah, I have the single hole tab ones - its about 4mm dia.
sawdust1
Postby sawdust1 » Sat Nov 19, 2016 10:28 pm
I weld 2" of rod on the back at the point where it will hang nicely. I use this stub to hold and manoeuvre the piece while coating it. I can then stand the stub in a tube welded onto a plate and the thing goes into the oven to cook. After it comes out and cools I cut the stub short, 1/2 inch. I can either put a cap on it that will allow it to hang on a ledge or leave the cap off and it goes into the wall just like a hanger nail.
Bigger pieces have an inch piece of bent rod stuck on with the same effect as a D ring.
home built 4x4 watertable. Qcad, SheetCam and Linuxcnc
Miller 375 Cutmate
Lincoln buzz box and a Miller Mig
KNK MAXX vinyl cutter
The adventure started with a Cricut cutter that I hacked.
Return to “Plasma Cutting Accessories & Related Tools Forum”
Users browsing this forum: miller7596 and 1 guest
