It is currently Fri Sep 21, 2018 11:40 pm
My homemade plate roller
This forum is for plasma cutting related tools and accessories. Discuss products and tools that have worked or not worked for you.
f_armer
Postby f_armer » Fri Oct 21, 2016 5:20 pm
This is what i came up with for a roller.
I used new drill stem and cut spacers for the 1" shaft for extra support, pounded them in, then welded ends up. They came out really straight.
The ends i used 3/8" plate.
The rest is self explanatory i think.
I rolled the 5/8" rebar for the 36" wheel with no problem.
It dimpled my rollers up a bit though. :(
I need to add springs under the top roller bracket. Something that can slip over the 5/8" adjustment bolts.
I just haven't found the right spring yet.
Re: My homemade plate roller
Postby acourtjester » Fri Oct 21, 2016 10:27 pm
Nice work you should be able to make things round with that.
What's your first project?
Everlast PM 256 tig
motoguy
Postby motoguy » Fri Oct 21, 2016 11:07 pm
I am incredibly interested in this. lol
f_armer
Postby f_armer » Sat Oct 22, 2016 9:26 pm
If anyone wants to build this thing here's the file.
I had a material list in the file but it seems to have disappeared now so i'll add it here.
The only special thing is to get the keyways cut in the shaft, unless you have a way to do that yourself.
I bent the 3/8" thick top bracket in my 20t press, but I had to heat it up to do it
2 7/8" drill stem (however long you want)
1" shaft (I left 4" sticking out all roller ends except on 2 rollers I left 8" on one end)
2" square tubing for the base
12- 1/2" bolts
8- 3/8" bolts (for the center joining bracket)
2- P205 1" pillow block and bearing
4- 2 bolt flange mount bearing
4- 6 1/2" long 5/8" fine thread rod
4- 1" shaft 1 1/2"long drilled in center to 5/8" hole
3- 1" hub for weld on sprocket (one is for turning wheel)
2- 12 tooth #50 chain weld on sprockets
2 ft #50 chain (also connector link)
I think thats it
Postby acourtjester » Sat Oct 22, 2016 10:22 pm
Here is a way to cut key ways in a shaft if you have a lathe
https://www.youtube.com/watch?v=eVgZol6Mfvo
Everlast PM 256 tig
pertneer
Postby pertneer » Sun Oct 30, 2016 7:12 am
what diameter, length and wall are the rollers?
4'x8' CNC Plasma w/Water Table Running a Powermax 65 :D
CandCNC, Mach3, SheetCam, Millwrite Plasma V6
f_armer
Postby f_armer » Sun Oct 30, 2016 4:52 pm
pertneer wrote:what diameter, length and wall are the rollers?
2-7/8" diameter
35" long
1/4" wall thickness
sr guy
Postby sr guy » Wed Nov 16, 2016 12:25 pm
have you pushed the limits on this yet?
LDR 4x8 w scribe :D
Miller syncrowave 250
Hobart ironman 230
Baliegh tn 250
Bantam 12 ton 48"
JD2 model 32
Flashburn
Postby Flashburn » Sat Jan 07, 2017 3:28 pm
How thick of plate have you rolled?
motoguy
Postby motoguy » Mon Jan 09, 2017 10:15 am
Flashburn wrote:How thick of plate have you rolled?
I'm interested in knowing this as well. Thanks again!
tnbndr
Postby tnbndr » Mon Jan 09, 2017 10:31 am
Now add power!!
LDR 4x8, Scribe, DTHCIV
PM45
Miller 211
RW 390E Slip Roll
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
Dingo745
Postby Dingo745 » Sat Jan 14, 2017 2:32 am
Nice job and thanks for the file, I will have to make one for myself.
I made years ago, that also doubled as a bead roller and I did some ally tin work for a mates race car.
I love homemade tools :)
f_armer
Postby f_armer » Sun Jan 15, 2017 5:47 pm
I tried a full 35" of 12 gauge, and it rolled not bad, but my down pressure adjusting bolts started to flex inward a bit. I was trying to roll it into about an 8" dia. Just as a test.
I haven't tried to test it's max abilities other than that.
It'll roll narrow 1/4" without a sweat.
The rollers seem lots strong, the weakness would be in the threaded rod
Return to “Plasma Cutting Accessories & Related Tools Forum”
