Slip Roll Designs
Slip Roll Designs
Making a small 3 roll slip roll to use in making rings.
Will be designing a 4 roll when I am finished with this one.
EZ Router APC 4 x 8
V- Carve Pro
SheetCam
Mach3
V- Carve Pro
SheetCam
Mach3
Re: Slip Roll Designs
What gauge will it be rated for? And HOW MUCH? Looks great good job.
I would like to know as well!
Looks great!
Looks great!
PlasmaCam DHC2
Hyperthem PM65
Edwards 25T Ironworker
Hyperthem PM65
Looking for one how munch an how thick of metal will it roll. thanks johnd123
All,
I am starting the build this weekend. I believe it can roll up to 1/8" x 12". Of course we will see how it performs during its prove out. At this I do not plan on making them and selling them. If it proves out, I would probably look at creating prints for those who may want to make one. Let's see how the protoype performs and go from there. BTW, I am planning on using the HF pipe threader for powering it.
Paul
Paul
Looking forward to the progress report and even at 1/8 X 12 I am more than willing to buy your plans!
Carl
Carl
PlasmaCam DHC2
Hyperthem PM65
Hyperthem PM65
Good luck I am looking forward to seeing this done.
- HammerDownJustin
Any updates" curious how the pipe threader worked if you tried it
Miller 251 Mig
Miller 251 Mig
No updates, another job moved ahead of this. I hope to start this week.
EZ Router APC 4 x 8
V- Carve Pro
SheetCam
Mach3
V- Carve Pro
SheetCam
Mach3
Visual in response to a question received about rotation of rolls.
Two rolls on left are outside of plate, two rolls on right are the actual rollers, not shown is the radius roller which would be on the far right on an angle to create the bend.You currently do not have access to download this file.
EZ Router APC 4 x 8
V- Carve Pro
SheetCam
Mach3
V- Carve Pro
SheetCam
Mach3
End up going anywhere with this?
Will be starting the build of this project this week, updates to follow.
EZ Router APC 4 x 8
V- Carve Pro
SheetCam
Mach3
V- Carve Pro
SheetCam
Mach3
