It is currently Tue Aug 21, 2018 11:47 pm
Question on muriatic acid
csmith
Re: Question on muriatic acid
Postby csmith » Thu Jul 26, 2012 6:55 pm
be aware that the fumes will corrode metal surfaces, so keep it ventilated, preferably outdoors
Digiroute 500 CNC Router (3x5 cutting area)
Deltacad 7
Vectric Aspire 3.5
Mach 3
metzindustries
Postby metzindustries » Sat Aug 11, 2012 8:10 pm
Here it is 7 dollars for a gallon of 25% or about the cost of one American made flapper disc.
I just pour a little in a plastic tub about one inch and another inch of water. Using goggles, rubber gloves and apron.
45 minutes removes my mill scale, the dross takes much longer.
To stop the post acid rusting, I have a second tub with baking soda and water. I neutralize the acid, then wash with plenty of water.
Then I hit it with a flapper disc to remove that grey powder looking stuff. It will stay rust free for a couple weeks even here on the tropical island.
I also found that longer soaks make the corners rounded which is nice when doing lettering to give them more of a cast metal look.
muzza
Postby muzza » Sun Aug 12, 2012 1:44 am
metzindustries wrote:I just pour a little in a plastic tub about one inch and another inch of water.
Just a note, you should always add acid to water, never water to acid
Murray
signsbyhansen
Postby signsbyhansen » Fri Oct 26, 2012 10:36 am
There is no way that I could store this stuff outdoors. We live in -40C weather. Any suggestions for storing indoors?
Thanks in advance.
rottenleonard
Postby rottenleonard » Thu Nov 15, 2012 5:43 pm
So I have about 4 gallons of this stuff that seems pretty used up, it no longer effects the metal, and if i put a little baking soda into it it doesn't foam. I would add more acid but my resivour is full. what can i do with this? can it just go down the drain? or in the driveway? or would I be causing a ecological disaster?
modelaratrod
Postby modelaratrod » Mon Sep 23, 2013 12:42 pm
Does anyone have a part # or brand of Muriatic acid? All I'm finding is "safer" than Muriatic acid, and the usually translates into doesn't work as well. lol
Thanks.
5x10 Torchmate 2 w/AVHC
Hypertherm PM85 w/ machine & hand torch.
kbenz
Postby kbenz » Mon Sep 30, 2013 9:03 pm
modelaratrod wrote:Does anyone have a part # or brand of Muriatic acid? All I'm finding is "safer" than Muriatic acid, and the usually translates into doesn't work as well. lol
Thanks.
Lowes http://www.lowes.com/Search=muriatic+ac ... atic+acid#!
CandCNC
Mach3
Draftsight
Hypertherm65 machine torch
Millermatic 210
Spoolmatic 30a w/ WC-115a
Miller Bobcat 225
VPT
Postby VPT » Wed Nov 30, 2016 8:52 am
Does white vinegar freeze? I live in WI and am trying to figure out what to do for cleaning parts.
Postby tnbndr » Thu Dec 01, 2016 7:46 am
Put a bottle of it in your freezer and find out? My guess is that it will as it is mostly water!!
I keep mine in the basement.
PM45
Miller 211
RW 390E Slip Roll
