It is currently Sun May 27, 2018 7:40 pm
Removing dross, mill scale from plasma cut parts
thefabguy
Re: Removing dross, mill scale from plasma cut parts
Postby thefabguy » Wed Sep 18, 2013 12:27 am
I tried the muriatic acid tonight, and I cant believe how great it worked! Unreal! 1:1 mixture with water....The material is .059 HRS, and I let the parts sit in the solution for 3 hours, and they were totally burr/dross free! The scale is gone, and the parts look fantastic! Man what a time saver! I retrieved the parts with a long magnet, and rinsed them in clean water, then a quick wipe or two with a WD40 soaked shop towel. I just cant believe how great this works!
Thanks for all the lessons guys!
bigjondrags
Postby bigjondrags » Mon May 26, 2014 12:13 am
how long does the acid water mixture last? ive been using my tank for about 5 months and seems like its not working very well anymore and it turned cloudy rusty the other day? should i just add fresh acid?
Gamelord
Postby Gamelord » Mon May 26, 2014 10:44 pm
Muriatic acid is suspended in water. It will eventually evaporate (which is why you need to cover it and also why you don't want it venting inside of your shop). Over time it will get weaker and weaker. Normally I just add another gallon of acid to the mix and all is well for a couple months. If the tub is getting to nasty, I will change out the entire thing and go all new....but that is usually only once every 8 to 12 months for me.
Torchmate CAD
Masons Forge
Postby Masons Forge » Thu Feb 05, 2015 11:28 pm
I use the acid mix also but my tumbler is a little different. I have a small concrete mixer that doesn't have paddles in it. My first mixer was from harbor freight, I wore it out in 3years next was one from Home Depot, works great. For the media I use sweeping compound or clean sweep the Zep brand works best. The first few times you use it the parts will have a film on them until the compound dries out a little I add dry play sand to the mix to help dry it out faster. After I use it a few times I add a little more compound. If it is throwing dust add more until it stops.
I first used this to knock the forge scale off everything I forged. Hope this helps
RevvedAC
Postby RevvedAC » Tue Feb 10, 2015 9:40 pm
Great info guys! Anybody have suggestions on where to find a bin with a lid that would fit 24" x 24" pieces? I'd like to be able to put a lid on to store the acid in the same container.
Sean
Jwagnon89
Postby Jwagnon89 » Fri Oct 13, 2017 5:55 pm
I'm cutting 18x18" 14 gauge pieces, can I stack them in the solution on top of each other or do they have to be the only thing in the acid?
steelfx
Postby steelfx » Sat Oct 14, 2017 11:10 am
You can stack them.
Bill
