It is currently Thu Mar 22, 2018 9:45 am
Removing mill scale with vinegar
Postby LISA » Wed Aug 30, 2017 2:15 pm
I have been testing many prep methods. I am currently working with vinegar to remove rust and mill scale. I have had very good results. It is not as expensive as hydrochloric acid and while it has a pungent odor it is not as hazardous to your skin either.
I filled a 55 gallon trash can with 30 gallons of white vinegar and began soaking. Over a weeks time I soaked 20 large pieces, 8-24 hours, with good results. I went over the piece with steel wool and rinsed with water. Because I am anal about prep I also ran over it with wire wheel but I really do not think that was necessary. The steel wool etches it. I just like to see that shiny look before I cover it with a finish!
I have no idea how long the vinegar will stay potent. I did test paint removal with vinegar and while it took several days it does lift high heat paint. I easily scraped it off.
Re: Removing mill scale with vinegar
Postby tnbndr » Thu Aug 31, 2017 12:07 pm
Not sure where you are located but look for a source of pickling vinegar, it is 12% acidic compared to the store vinegar at 4%.
I found a business near me that pickles eggs, etc for bar treats and they sell it to me for $1.75 a gallon.
LDR 4x8, Scribe, DTHCIV
Miller 211
RW 390E Slip Roll
AutoCAD, SheetCAM, Mach 3
Postby LISA » Sun Sep 03, 2017 5:51 pm
Thanks for the tip!
